Mugabetown - Whoretownin' At It's Worst.
Too f*cking cold to be walking to the train station this morning :S. Winter, please piss off now. K thx bai
I agree with that... I did not want to depart my warm spot on the couch in front of the TV this morning, then the office door wasn't shut properly by the boys this morning so the heater wasn't on and the office door had been open for 2 hrs before I got here, it's cold normally this morning I may as well have taken my computer outside! :yucky:
Winter is awesome, that is all. Now 30 degrees and 90% humidity while walking to the train at 7:30. That's a problem worth whinging about!
Hmm... I would much prefer that option!
There's going to be some Riots in Brazil today people. Watch the news for updates lol
Haha yayyyy!!!! Germany kicked ass!!! Hopefully they can keep it up next match! Such a good day to go to the German Club for dniner :cheers:
Dude at the tyre store today nearly jizzed himself when he found out I owned "WTF033",said he saw/heard it at the mighty mods meet and it sounded "tough as f**k" it's good to be famous :P
did you tell him it's got a dirty push rod engine it?
He already knew, had seen it with it's bonnet up at Mighty mods , everyone wants my car it's not for sale bro :P
It's ok. I already have a Ford POS station so thats bogan enough for me lol
  • Like 1
None you bisches except for pete can whinge about it being too cold. When I went to leave for work this morning at quarter to 7 it was 2 degrees and with wind chill it felt like negative 1.7
Hahaha, I dont know if being liked by the local bogans is famous..... Still noticing is noticing
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
