Im soon to be going apexi power fc and e85 tune (when all my gear arives) . but ive started with the fuel pump. (walbro 460l/h e85 series)
install went well, took 1h20m
but before i had my hdi set to 10psi, and was very satable,
but now, shoots to 10psi, sits there untill 4500rpm then creeps up to 14/15 psi
ive had to back it off to 7psi so it creeps to 11.
mods:
hdi ebc
blitz FMIC
decat
bell mouth dump-full 3inch exhaust
iridiums with .8 gap
splitfire coils
hks pod
drfit boost gauge.
any ideas as to why it does this will be nice!
Thanks
well, it was running perfect before i changed the pump. i would have thought that the mixture wouldnt change because it still has std injectors and fuel pressure reg.
so, any one with a solution untill my apexi arives? it will be a good couple of months before its installed and tuned.
That's the point isn't it. The standard mixtures are very rich up top. Well, they are when you have the BRAND NEW standard pump and reg. But add 15 years onto the pump and now it doesn't want to keep the pressure up when it's flowing at high loads and your injectors actually see lower pressure than intended. The mixtures are a bit leaner, the car goes really well. Everyone is happy.
Then you install a big pump that can keep the pressure up at high flows, and suddenly you're hosing fuel into it at the top end.
just another thought, shouldnt the ebc controll the boost. it wont let it go past 11psi if i set it at 7... so obviuosly the wate gate is capable of doing its job, as it can stop the boost from going past a certain point!
As above, theories are correct.
The EBC is only a cheapy, too. I have one I am going to install soon and I do not expect it to do that great a job of holding boost. Now that the mixtures have changed the EBC accounts for a different result.
Try disconnecting the EBC and just running actuator pressure, see if it then holds stable :)
I recently fitted a GFB G-Force II. Has some fairly good features: overboost, gain, sensitivity. Very happy with it. Fairly easy to set up if you have a highway or dyno nearby. Responds very well in situations I get myself into.......
No, its my first. Had a cheap manual unit. Will NEVER go that road again! Too uncontrollable. A dual solenoid unit would be better than the single, but couldn't afford $600+. Was thinking about the turbosmart e-boost street, but I still saved $200. I got it from eBay from MRT Performance.
Well, I've bought gfs one now. Hopfully its better thAn the hdi one. The programing seems like it should help. I've just bought a hi flow turbo so, ill be doing a few upgrades now, so well see how it goes.
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
