hey everyone, love the site.
allright well, i have a vs calais that i am putting an rb25det into, bought my donor skyline (r33) last week,
was thinking ill take the engine out and sell the stuff off the skyline to hopefully make the money i spent back on it.
just had a couple questions,
1# what is everyones opinions on a quality aftermarket ecu, the car is a manual, has 290rwkw for now.
it still has stock nissan ecu.
2# would 1000cc injectors be good for around 300-350kw?? or would an upgrade be in order and if so at what power would it be worth changing them over.
3# what would the problem be if when i start the skyline it starts blowing out light smoke from the oil catch can?
4# and would anyone know if i could use a vl manual front half of the tailshaft and have the original vs rear part?
anyone that has done this to a vs would love to talk, or even if someone could send me a link to someone thats done it would be a great help.
and by the way i dont need anyone telling me to ditch the commodore and keep the skyline, have alot of love for my calais and its very neat to.
cheers guys...
https://www.sau.com.au/forums/topic/431285-new-here/
welcome.
ok, ecus are all preference.
talk the guy youre going to tune the car, and find what they like.
most will have a preference, and get better results out of that.
im very happy with my haltech.
1000cc will be fine for that power level, but may run out up top if using e85.
smoke from catch can, could be worn rings/bores.
but, going for 350, if the engine isnt sound, youll find our soon enough.
https://www.sau.com.au/forums/topic/431285-new-here/#findComment-7001503
bloody hell, a reply that quickly i think i could really become attached to this website, back when i had my supercharged commodore i joined l67torque knowone ever replied.
thanks for your help mate, what type of haltech is yours.
and you wouldnt happen to know anyone on here thats put a rb25 into a vs by any chance??
https://www.sau.com.au/forums/topic/431285-new-here/#findComment-7001568
I have the platinum pro plug in.
I repky fast, because I have no life :(
but srsly, alot of people around here like cars in general, not just skylines.
so, the community is generally accepting.
dont know anyone who has done this conversion, but have seen it done.
there is a member on here by tje user name captain natro, he has done an ls1 into an r33....
https://www.sau.com.au/forums/topic/431285-new-here/#findComment-7001617
Welcome, your Calais looks awesome in that photo. Love the wheels/tyres and the tone of blue paint. There is a VR/VS wagon getting around with a Toyota V8 in it. Sounds great. LS1 conversions have a lot of off the shelf parts which makes them less of a headache but I guess you have your reasons choosing an RB25 to power your Calais. Good luck with it!
https://www.sau.com.au/forums/topic/431285-new-here/#findComment-7002491
that was an awesome thread luke, cheers for that. love the ls series, makes me miss my maloo ute:(
thanks loach, aprreciate it. yeah i would like an ls1 but i would need a pretty deep pocket which unfortunatly i dont, where as the rb practically a bolt in job, and the engine i have allready has 290rwkw which quite frankly ill be happy with:)
https://www.sau.com.au/forums/topic/431285-new-here/#findComment-7003112
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
