Hey guys,
keen to clear this stuff out so everything is priced very fair.
car was a 4 door gtt in sonic silver
i prefer pick up but if you pay postage ill post anything anywhere
located in Newcastle NSW
very rare factory carbon fibre cluster (auto) 200
Drivers door 100
drivers rear door 100
boot lid 100
rear bar 100
drivers side front guard 50
front seats 100
rear seats 100
tail lights (sedan lights, different to coupe) 100
boot trim and carpet in mint condition (sedan) 100
standard jack and tool kit 50
space saver 50
windscreen washer bottle 50
front reo bar 150
rear reo bar 50
passenger radiator support 50
tail shaft (off gear box) 50
abs unit 50
brake booster and master cylinder 150
front wiper motor 50
rear wiper motor 50
horns 50
accelerator pedal 50
brake pedal 50
clutch pedal (with fill bottle) 50
cluster surround 50
fuse box from engine bay 50
hicas computer 50
this is absolutely everything i have.
buy buy buy, i want my yard back!
  • 4 weeks later...
Drivers side front guard - pretty keen on this. Are you able to pack and freight to Adelaide?
do you have the headlight bracket thingies that mount to the front reo? i need the passenger side one, am willing to take both though.
  • 3 weeks later...
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
