Save money, sell car, buy GTR, ???, Profit?
or
Fluids, brakes and rotors etc. Then spend 6k on tyres and entry fees into sprint days, hill climbs, drift days, skid pans etc.
or
6-7k on hookers and blow.
All 3 options are better avenues than a slight power upgrade in a 33...
So coming to end of the year ill be finished with paying off the car.
Want to upgrade the car
All suspension side is sorted(away bars, coil overs, bracing, bushes etc.)
So I was thinking front mount with plenum gtr style, 80mm throttle body, upgraded fuel rail, hi flow 34 turbo, electronic boost tee, electronic bov, 450lph fuel pump, 550cc injectors, Ecu ( not sure on Ecu yet), fix the zorst and new clutch and clutch lines
Then a pain after all that
Any other mods? Or suggestions to not do some? Or brands
anything
Inputs
Coments
Numbers for new to town ladies
Cheap parts
plenum is a waste of money with such little mods, ditto for the throttle body and fuel rail.
550 injectors in the standard fuel rail with the standard fuel pressure regulator.
boost controller, high flow turbo or similar bolt on kit, stock bov with the top crushed to increase spring pressure (there is a thread on here about it somewhere) 255lph fuel pump, 400 is overkill.
all you blokes saying full fluid flush and better fluids, done.... first thing when i got the car
new engine oil every 4000 and the gearbox diff got flushed out new oils and the additives aswell
clutch and brake fluid is racing dot 4
coolant done the other week
fpr is stuffed so i need a new one, and the dampener.
bov leaking
more just research and saving atm so i know what i need to save for
so if anyone can give me brands they recommend that would be MAD!
This. About $400 for the fronts tho.
If I recall going through brakesdirect/ GSL rally they were $180 per rotor for front and yeah as Tony said $80 for the HPX pads.
GTR radiator could help. They're full aluminium and a cheap upgrade.
Pretty sure they are identical to the gtst one alloy core plastic end tanks.
The mods sound about right.
Nistune
R34 highflow
500ish cc injectors
Fuel pump? If not already done.
Front mount, I reccommend the return flow ones.
Boost controller
Some sort of plumbed back bov and boom 270 to 290rwkw of super fun happytimes.
Forget the plenum. I made 330rwkw using the stock one. You will be fine.
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
