Save money, sell car, buy GTR, ???, Profit?
or
Fluids, brakes and rotors etc. Then spend 6k on tyres and entry fees into sprint days, hill climbs, drift days, skid pans etc.
or
6-7k on hookers and blow.
All 3 options are better avenues than a slight power upgrade in a 33...
So coming to end of the year ill be finished with paying off the car.
Want to upgrade the car
All suspension side is sorted(away bars, coil overs, bracing, bushes etc.)
So I was thinking front mount with plenum gtr style, 80mm throttle body, upgraded fuel rail, hi flow 34 turbo, electronic boost tee, electronic bov, 450lph fuel pump, 550cc injectors, Ecu ( not sure on Ecu yet), fix the zorst and new clutch and clutch lines
Then a pain after all that
Any other mods? Or suggestions to not do some? Or brands
anything
Inputs
Coments
Numbers for new to town ladies
Cheap parts
plenum is a waste of money with such little mods, ditto for the throttle body and fuel rail.
550 injectors in the standard fuel rail with the standard fuel pressure regulator.
boost controller, high flow turbo or similar bolt on kit, stock bov with the top crushed to increase spring pressure (there is a thread on here about it somewhere) 255lph fuel pump, 400 is overkill.
all you blokes saying full fluid flush and better fluids, done.... first thing when i got the car
new engine oil every 4000 and the gearbox diff got flushed out new oils and the additives aswell
clutch and brake fluid is racing dot 4
coolant done the other week
fpr is stuffed so i need a new one, and the dampener.
bov leaking
more just research and saving atm so i know what i need to save for
so if anyone can give me brands they recommend that would be MAD!
This. About $400 for the fronts tho.
If I recall going through brakesdirect/ GSL rally they were $180 per rotor for front and yeah as Tony said $80 for the HPX pads.
GTR radiator could help. They're full aluminium and a cheap upgrade.
Pretty sure they are identical to the gtst one alloy core plastic end tanks.
The mods sound about right.
Nistune
R34 highflow
500ish cc injectors
Fuel pump? If not already done.
Front mount, I reccommend the return flow ones.
Boost controller
Some sort of plumbed back bov and boom 270 to 290rwkw of super fun happytimes.
Forget the plenum. I made 330rwkw using the stock one. You will be fine.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
