Hey guys, i've got a bunch of R33 performance bits taking up space, so they're all up for sale. Located in Sydney for pickup or I can post:
Kaaz 2-way 4.1 LSD Diff in R33 housing - $850 ono
Set of 18x9.5" ROTA Grid wheels at tyres. Great condition, one of the wheels has some light gutter marks but the others have basically none - $1200 ono
All are 5x114.3, 18x9.5" +38. Tyres are 235/40 Federal ss595 - rears have some camber wear and are probably not roadworthy - fronts have a bit left at maybe $25% above markets
Greddy style rb25 intake plenum, polished/silver. Includes 80mm throttle body, TPS, AAC valve, etc - $450
post-35556-0-03794300-1379334062_thumb.jpg post-35556-0-27842800-1379334075_thumb.jpg
RB25 Stainless steel high mount manifold & external wastegate - $350 ono
post-35556-0-10589800-1379334255_thumb.jpg post-35556-0-47184100-1379334276_thumb.jpg
Matching the above - stainless custom dump/front pipe (garrett 4-bolt flanged) - $100
Blitz Dual SBC Spec-S electronic boost controller. Includes solenoid, all wiring looms - $300 ono
Bosch 040 fuel pump and R33 Cradle - $120 ono
HKS Hiper-D height and damper adjustable coilovers. Great condition - $700
Rears were originally for GTR only but have been modded to suit R33 Gts-t
Return flow FMIC & piping kit for R33 Skyline Gts-t - painted black.
Pretty good condition, but the lower return pipe & end tank have some scrapes on the under side - $250 pickup only
post-35556-0-44984300-1379334512_thumb.jpg post-35556-0-28848800-1379334523_thumb.jpg
3" catback exhaust system. Front section is X-force, rear is a stainless a-spec straight through dual tip - looked great on the car - $200 pickup only
post-35556-0-08221500-1379334577_thumb.jpg post-35556-0-26989300-1379334587_thumb.jpg
SRI Bolt on wheel spacers, 5x114.3 - 20mm and 15mm - $75/pair
post-35556-0-93527700-1379334095_thumb.jpg post-35556-0-03926900-1379334330_thumb.jpg
Complete rear Hicas lock bar & arms, ready to bolt on - $100
  • Like 1
What brand is the exhaust manifold and gate? Cheapie? How much use? What flange? Suit stock rear turbo housing? Pretty interested.
Edited by FordyR31
Kaaz diff, fuel pump, dump pipe sold
Coilovers and hicas bar on hold pending pickup this weekend
Stainless exh manifold is t3 flanged, 38mm adjustable wastegate, can't see any brands but they're both in top condition
HKS coilovers Kaaz diff, Bosch 040 & hicas lockbar sold. Still have all the rest
Price drop!:
Greddy style plenum - $400
Stainless exh manifold & gate - $300
ROTA wheels - $1000
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
