Hey guys, i've got a bunch of R33 performance bits taking up space, so they're all up for sale. Located in Sydney for pickup or I can post:
Kaaz 2-way 4.1 LSD Diff in R33 housing - $850 ono
Set of 18x9.5" ROTA Grid wheels at tyres. Great condition, one of the wheels has some light gutter marks but the others have basically none - $1200 ono
All are 5x114.3, 18x9.5" +38. Tyres are 235/40 Federal ss595 - rears have some camber wear and are probably not roadworthy - fronts have a bit left at maybe $25% above markets
Greddy style rb25 intake plenum, polished/silver. Includes 80mm throttle body, TPS, AAC valve, etc - $450
post-35556-0-03794300-1379334062_thumb.jpg post-35556-0-27842800-1379334075_thumb.jpg
RB25 Stainless steel high mount manifold & external wastegate - $350 ono
post-35556-0-10589800-1379334255_thumb.jpg post-35556-0-47184100-1379334276_thumb.jpg
Matching the above - stainless custom dump/front pipe (garrett 4-bolt flanged) - $100
Blitz Dual SBC Spec-S electronic boost controller. Includes solenoid, all wiring looms - $300 ono
Bosch 040 fuel pump and R33 Cradle - $120 ono
HKS Hiper-D height and damper adjustable coilovers. Great condition - $700
Rears were originally for GTR only but have been modded to suit R33 Gts-t
Return flow FMIC & piping kit for R33 Skyline Gts-t - painted black.
Pretty good condition, but the lower return pipe & end tank have some scrapes on the under side - $250 pickup only
post-35556-0-44984300-1379334512_thumb.jpg post-35556-0-28848800-1379334523_thumb.jpg
3" catback exhaust system. Front section is X-force, rear is a stainless a-spec straight through dual tip - looked great on the car - $200 pickup only
post-35556-0-08221500-1379334577_thumb.jpg post-35556-0-26989300-1379334587_thumb.jpg
SRI Bolt on wheel spacers, 5x114.3 - 20mm and 15mm - $75/pair
post-35556-0-93527700-1379334095_thumb.jpg post-35556-0-03926900-1379334330_thumb.jpg
Complete rear Hicas lock bar & arms, ready to bolt on - $100
  • Like 1
What brand is the exhaust manifold and gate? Cheapie? How much use? What flange? Suit stock rear turbo housing? Pretty interested.
Edited by FordyR31
Kaaz diff, fuel pump, dump pipe sold
Coilovers and hicas bar on hold pending pickup this weekend
Stainless exh manifold is t3 flanged, 38mm adjustable wastegate, can't see any brands but they're both in top condition
HKS coilovers Kaaz diff, Bosch 040 & hicas lockbar sold. Still have all the rest
Price drop!:
Greddy style plenum - $400
Stainless exh manifold & gate - $300
ROTA wheels - $1000
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
