Hey guys, ive got a question I couldn't specifically find the answer to.
Is toe affected when adjusting rear camber on an R33 GTST, using adjustable rear camber arms (upper arms), like these? >>
308-S14%20R33%20Rear%20Camber%20-%20Smalhardrace-rear-UCA-s14s15r33r34c34c35.-pi
If it is affected, how much would it change vs camber?
Does that makes sense?
ie. I adjusted the rear camber myself, adding about 1 degree positive. From my measurements & calculations, around -1.8 deg >> to -0.8 deg. (possibly off, but moved + towards zero some amount)
18 inch wheels, so lip to lip, rim height measures 495mm.
Cheers
As far as I know, yes. Camber and toe are normally adjusted together when doing an alignment. I'd suggest dropping by at a wheel joint and getting them to measure it for you?
It will almost certainly affect toe, and using my logic: adding negative camber will increase toe-in, subtracting negative camber (as you've done) will increase toe-out.
Did you adjust both upper arms for camber?
The change in toe would be minimal but you'd want to verify it by taking it to a shop.
Edited by colourclassic
I would have said the exact opposite. Assumnig you do not change the lengths of the radius/traction arms, then shortening the upper arms (adding neg camber) will effectively push the front of the wheel outward. This is because the traction arm stops the front of the upright leaning inward with the rest of it as the neg camber is increased.
Logically, in order to increase neg camber without causing toe out, you would also need to have adjustable traction arms that you could shorten at the same time.
As to how much.....well, toe is measured in mm and camber in degrees, so it would be hard to come up with a relationship that made sense without going and measuring everything carefully. But I would estimate that because the traction arms are about 45° to the upper arm, then you'd get about 1/sqrt(2) change in toe angle with each change in camber angle. Or about 70% of the camber angle change might turn up as toe change. Might be a bit less, depends on how close to 45° that arm is, and also the influence of the tie rods/toe rods at the rear. What might actually happen is that the traction arm bushes end up soaking up a lot of the force and so you don't actually see so much angle change but you do increase the binding load in the traction arm bushes.
Good point, I was assuming you adjust the traction arm with the upper arm when adjusting camber to compensate for rake/caster changes? If that was the case then the HICAS linkages would dictate toe. If in fact you only adjust the upper arm, then your theory would be correct. Any suspension experts out there?
Edit: It looked like he does have adjustable traction arms, hence my logic stated above.
Yes, i thought as much re: toe being affected one way or the other..
Just wasnt sure.
Do you mean both sides (driver and passenger) equally? Yes.
I adjusted both sides to about 7-8mm below zero camber. (495mm / 8mm) x (INV)tan = 0.89 degrees.
Of course i did this at home, and didnt use precision measuring tools, but it looks good to me.
However, toe is much harder to measure and gestimate, so I should prob get this looked at anyway.
No, I meant did you adjust both the 'camber' and radius/traction arms on both sides? It looks like both your upper arms are adjustable on each side. The Nissan multi-link is a pretty complex setup, and adjusting just one parameter changes the whole suspension dynamic; toe, caster, camber etc.
no thats not a photo of my car. Just showing which type of adjustable arms i was using.
i only have the one that bends around the coilover. as in the 2nd pic.
i dont think there is any adjustment in the other arm in stock form.
ive had my camber adjusted a while ago, and the guy had it spot on. but since then it's been lowered a little more and it was bugging me, hence the home adjustment.
Ah! That explains it then. If you only have adjustable camber arms, and non adjustable traction arms, then GTSboy is right, your toe has increased inwards.
yeah but I'm pretty sure you can rectify that by adjusting the hicas (lock bar) rods.
also, i'm pretty sure i can feel more rolling resistance now. so thats what made me think maybe toe was not zero anymore.
FYI for future searches.
I had the rear alignment done.
My calculations were a little out. I had -1 degree on the passenger side, -1.2 degree on the drivers side.
The toe had hardly been affected. Was sitting on zero. I suspect it was previously just under zero.
So i guess adding positive camber = increase in toe out??
Anyway, new rear alignment is -0.8 deg, 0 toe. I think that's reasonable for street driving.
Cheers for the help guys!
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
