Hey guys, ive got a question I couldn't specifically find the answer to.
Is toe affected when adjusting rear camber on an R33 GTST, using adjustable rear camber arms (upper arms), like these? >>
308-S14%20R33%20Rear%20Camber%20-%20Smalhardrace-rear-UCA-s14s15r33r34c34c35.-pi
If it is affected, how much would it change vs camber?
Does that makes sense?
ie. I adjusted the rear camber myself, adding about 1 degree positive. From my measurements & calculations, around -1.8 deg >> to -0.8 deg. (possibly off, but moved + towards zero some amount)
18 inch wheels, so lip to lip, rim height measures 495mm.
Cheers
As far as I know, yes. Camber and toe are normally adjusted together when doing an alignment. I'd suggest dropping by at a wheel joint and getting them to measure it for you?
It will almost certainly affect toe, and using my logic: adding negative camber will increase toe-in, subtracting negative camber (as you've done) will increase toe-out.
Did you adjust both upper arms for camber?
The change in toe would be minimal but you'd want to verify it by taking it to a shop.
Edited by colourclassic
I would have said the exact opposite. Assumnig you do not change the lengths of the radius/traction arms, then shortening the upper arms (adding neg camber) will effectively push the front of the wheel outward. This is because the traction arm stops the front of the upright leaning inward with the rest of it as the neg camber is increased.
Logically, in order to increase neg camber without causing toe out, you would also need to have adjustable traction arms that you could shorten at the same time.
As to how much.....well, toe is measured in mm and camber in degrees, so it would be hard to come up with a relationship that made sense without going and measuring everything carefully. But I would estimate that because the traction arms are about 45° to the upper arm, then you'd get about 1/sqrt(2) change in toe angle with each change in camber angle. Or about 70% of the camber angle change might turn up as toe change. Might be a bit less, depends on how close to 45° that arm is, and also the influence of the tie rods/toe rods at the rear. What might actually happen is that the traction arm bushes end up soaking up a lot of the force and so you don't actually see so much angle change but you do increase the binding load in the traction arm bushes.
Good point, I was assuming you adjust the traction arm with the upper arm when adjusting camber to compensate for rake/caster changes? If that was the case then the HICAS linkages would dictate toe. If in fact you only adjust the upper arm, then your theory would be correct. Any suspension experts out there?
Edit: It looked like he does have adjustable traction arms, hence my logic stated above.
Yes, i thought as much re: toe being affected one way or the other..
Just wasnt sure.
Do you mean both sides (driver and passenger) equally? Yes.
I adjusted both sides to about 7-8mm below zero camber. (495mm / 8mm) x (INV)tan = 0.89 degrees.
Of course i did this at home, and didnt use precision measuring tools, but it looks good to me.
However, toe is much harder to measure and gestimate, so I should prob get this looked at anyway.
No, I meant did you adjust both the 'camber' and radius/traction arms on both sides? It looks like both your upper arms are adjustable on each side. The Nissan multi-link is a pretty complex setup, and adjusting just one parameter changes the whole suspension dynamic; toe, caster, camber etc.
no thats not a photo of my car. Just showing which type of adjustable arms i was using.
i only have the one that bends around the coilover. as in the 2nd pic.
i dont think there is any adjustment in the other arm in stock form.
ive had my camber adjusted a while ago, and the guy had it spot on. but since then it's been lowered a little more and it was bugging me, hence the home adjustment.
Ah! That explains it then. If you only have adjustable camber arms, and non adjustable traction arms, then GTSboy is right, your toe has increased inwards.
yeah but I'm pretty sure you can rectify that by adjusting the hicas (lock bar) rods.
also, i'm pretty sure i can feel more rolling resistance now. so thats what made me think maybe toe was not zero anymore.
FYI for future searches.
I had the rear alignment done.
My calculations were a little out. I had -1 degree on the passenger side, -1.2 degree on the drivers side.
The toe had hardly been affected. Was sitting on zero. I suspect it was previously just under zero.
So i guess adding positive camber = increase in toe out??
Anyway, new rear alignment is -0.8 deg, 0 toe. I think that's reasonable for street driving.
Cheers for the help guys!
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
