Here is a video of the knock from underneath the oil pan. https://www.facebook.com/photo.php?v=10202158035533359&l=7946916124426248770 I shut the car down once the knock was over. After those first few it stops. Going to start tearing into it tomorrow. plans are to go over the timing belt/ tensioners. cut open oil filter see how that looks, and drop the oil pan have a look in there.
=x Full tear down is necessary you would assume from that mild knock? It only does it on full cold starts. Im going to drop the pan and check the crank for out of round, but only being able to get 2 points checked isnt proper ><
What oil filter are you using? If the anti drainback valve is leaking overnight it can take a few seconds to pump the oil up. Mine was doing a similar thing with a certain brand filter. I changed to K+N and never looked back.
Is it fine at all other times and just does this at startup? No other noises?
That seems pointless.
^ yeah I don't know what I was saying :domokun: well the motor is out of the car now, should be on a stand tomorrow. It was not the oil filter drain back valve, i tested it did not leak a drop :( Guilt-Toy seems to be correct. I'll know in a day or two. Pictures to come. And picking up a s2 long block tomorrow. Any chances I will be able to get it to work with my NEO ECU/Harness?
You pulled the engine already? I would have cut open the oil filter and dropped the sump to see if there was bearing particles first.
Keep us posted, I think the cas is different between the two engines, and a few other small differences.
Yeah the motor was in a 240sx super easy to pull. I was in need of a new timing belt and water pump a few seals and pulleys. No signs of bearing in the oil filter, my last oil sample came back pretty regular but there's no telling until I tear it down. Any tips for When I pull the head to keep any stray coolant from getting down the cyl. Don't want a bunch of glycol getting down there if everything ends up looking healthy and it was just a bad tensioner pulley or oil pump
I asked because #6 can be leaned out by a bad plenum. Even without that possibility, #6 often suffers before the other cylinders because it runs hottest. I suppose you could/should go looking for things like bad injectors/plugs and possibly even oil squirters for other reasons why it might have pinged itself to death.
I'm assuming I should go ahead and port out this oil drain? if I do this and put in the restrictors should I still pop out that rear welch plug and install a drain right to the sump. (drift car) I would like to not need to install a drain.
External vents are almost essential. If you don't provide them then ALL the air flow from the bottom of the engine up to the top has to pass up through the drains, against the flow of oil. The extra up velocity makes it hard to get the oil to go down. Add in some extra flow area, velocity goes down, drainage works better.
Edited by GTSBoy
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
