Hey Guys,
well I put it off for as long as possible, but I just can't justify hanging onto her.
Selling a very clean, neat and close to stock standard genuine 1997 series 3 BCNR33 GT-R. With all the bits and pieces that make the series 3 that little bit nicer, like the red trim on the interior and the xenon headlights (which on this car are not cloudy and yellow like many others) In excellent condition, there are minimal non factory parts on the car. Do Luck floor brace, carbon fibre blade on the rear wing, carbon fibre look dash pieces, Blitz Dash Cluster showing 85344kms - real kms unknown but judge the cars condition, it's very tidy! HKS catback exhaust and a boost guage. I *think* that's about it. The engine is stock and has recently had a FULL service, including timing belt, water pump, tensioner etc. Also all new fluids throughout, new spark plugs etc - car has done no driving since all of that was carried out. This is no maintenance moneypit waiting to happen as all the big bucks have just been spent. Brand new tyres on the factory wheels.
Price includes RWC and 12 months registration
Inspections are welcome, happy to take the vehicle to a nearby workshop for a mechanical inspection as well. For serious buyers, I will arrange an unregistered vehicle permit for a test drive. Is fitted with an alarm/immobiliser and remote central locking also.
$20000 ono.
Contact through here or via email to [email protected] or phone at 03 90080031
https://www.sau.com.au/forums/topic/432624-fs-mlb-1997-bcnr33-gt-r-in-white/
I know for sure that I'd be struggling to find one in Japan in this shape and bring it in for these sorts of $$ nowadays, as the really clean GT-Rs are appreciating in value year on year over there
But I did price it tight in hopes of moving it on quicker, rather than putting a higher price tag on it and sitting on it for a few months waiting for the right person to come along.
hmmmm tempting, dunno if I can handle the power :)
Pfft softcock :P
GLWS regardless! Wish I could snap it up though, kinda the only car that'd get me back into Skylines.
Pfft softcock :P
haha, well maybe you should send me some info on this Caddy - probably an easier sell than a Skyline so it could work out ;0)
  • 7 months later...
  • 1 month later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
