Drom e85? Why drum?
A single 044 won't be enough. Should have saved the money from buying the drum, filled at United and bought a $200 Walbro e85 pump imo.
E85 isn't overly common up here so depending on where he lives it could be quite the trip there and back. Also helps when tuning if the tuner isn't close to an E85 servo.
I'm running from drum E85 now and pretty happy with first results at low boost
What size walbro in tank you got? Sound like it should be fine with those mods..
I'm addicted to pulling up at the lights and letting the fuel smell catch up
:yes:
Edited by Noy
  • Like 1
Update:
So we now know the limits of an external 044 and wall bro intank with the the surge tank.
Topped out at 534whp at 24/25 pound.
Leaning out with any more boost.
Now awaiting the second 044 hopefully close to 600 is what I'm hoping for
I'm addicted to pulling up at the lights and letting the fuel smell catch up :yes:
Haha fully agree with you about the smell.
Smells so good.
And the workshop I help alot at always has drum e85 so I just run what they have basically pretty happy with the results so far. Look out with the second 044
And yea just is a bit of a journey to united especially if it is peak traffic
Yeah mate. Bit of a trip. From my place, which is only 15min from the city, it would take about an hour in traffic - if not a little more. Hence the use of drums.
Update:
Nicely done mate! Also, with any pointers, Noy would be the guy to ask as he's building a wicked 34 on e85. :)
Nice man thanks for the info will definitely keep noy nd the rest of you guys in the loop.
Appreciate any info to help.
But I guess we have proved many a people wrong with not being able to see 500whp on e85 with 1 external 044
Sorry noy for taking a whisk to reply.
I'm using a 500hp wallbro intank will have to check for the exact pump it is
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
