Hey guys,
I have Federal 595 SS tyres, 265/35/18 and tried getting them put onto my stock R34 GTR rims, however for some reason the tyres weren't fitting completely - part of the tyre was catching and wouldn't push over the inner 'lip' - the tyre guys put up to 80psi into the tyre to try and push it out, but still didn't work.
Does anyone know the reason for this, or has anyone had this problem before?
They thought they it might've been because the tyre had contracted slightly in the cold, and are going to put some heat through them to stretch them out, but are otherwise at a loss as to why this would occur.
Any help as to how to fix this would be greatly appreciated!
Yeah I was one of the people who couldn't get 595RS on R34 rims, they tried over 120psi to pop it on. There was at least one other person with the same problem.
On the other hand I do now have 595SS on those same R34 GTR rims....so get them to try a little more pressure ;)
The underlying issue is basically that both Nissan and Federal push the limits of "compatibility" in the angle of their rim edge and bead respectively because both were trying to get top performance....the issue shows when you try and put a very aggressive tyre on a very aggressive rim.
The shop I had fitting it had been doing tyres for 50 years and had never come across the issue (some tyres need more pressure, but they had not seen one they could not fit with enough pressure), and frankly if it hadn't happened to me I'd probably call bullshit :)
Ok thanks for the info and advice Duncan, I'll suggest 120psi but they were quite reluctant for obvious reasons (we were hiding behind machines at 80psi)
Perhaps if heating it up to make it stretch out a bit doesn't work, then 120psi could be pushed, but likewise with these blokes, they'd been doing it for over 30 years and never seen the problem before
Cheers mate!
umm yeah I should be clear....it is their tyre shop and their call on what they think is safe :) Don't just trust some nobody on the internet.
You could also get them to contact Federal's office, and in particular Mick Hart from Canberra...he knows the story and has had one of their techs look into this previously
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
