Hi all. I have a 89 gts4 and I just wanted to know how it works because my 4wd light on the dash is there. And there is a torque controller with a 4wd amd 2wd switch and a dial. But my concern is the guage on the dash for front torque doesnt move. If you need any more info just ask. It has a gtr box in it and im.pretty sure the tranfer csse is still there
https://www.sau.com.au/forums/topic/432794-gts4-4wd/
You open your wallet and start shaking money on the problem until it goes away. Seriously, are you going to ignore the comment above about searching? This type of problem has been bleated about on here about thirty frumptillion times since the forum started. You could search for similar terms, you could search for "AWD diagnostic" or "ATTESSA light" and you should get heaps to wade through.
https://www.sau.com.au/forums/topic/432794-gts4-4wd/#findComment-7052747
Could be as simple as a blown fuse/ no fuse for the AWD system, although I'm unsure if that also means the gauge will read nothing as I haven't looked at the gauge when having a blown fuse.
Well I checked the pump thing it still pimes when I bridge those two wires together. But I counted the attessa light and I got numbers.
8, 9, 18 or 19, and 21 so yeah 4 issues with the system. And I dont know why or how to go about fixing them.
https://www.sau.com.au/forums/topic/432794-gts4-4wd/#findComment-7053454
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
