No that's the rub I'd have to buy it , there are a lot cheaper ones around so ill have to look into it, but those tune results I posted the other day were my car with a programable ecu an a tune, that's all that's missing from getting into the 280rwkw range, but he said 230-240 would be safe as houses to run with the current running gear already there.
Daryl it really depends on what you want out of it.
Best bang for buck is going to be the nistune.
I honestly think you need to sit down and work out exactly what your plan is.
Otherwise you are going to have all these mismatched parts and no idea of what you actually want.
Set yourself a goal and then research how to get there.
Are you looking to get to that power goal the easy and cheap way or the safer and more expensive way.
I made the mistake of focusing purely on power and neglecting handling, braking and general maintenance.
This left me with a 250kw car that feels like shit to drive these days.
Parts need to talk with each other or else they're just junk in the trunk huehue.
I suggest talking with someone (with knowledge) and aim for a power outlet - If you're wanting 300kW then ask a specialist on what supporting mods you need to get that.
Figure out what you want in the end game and work towards it - it's not a cheap journey.
cheers
Edited by RosieR34
Just got hold of the guy that did up the car, he spent 13000$ on it
It has an adjustable arm on the antenuator to a just boost so a just nut back toward cabin lower , towards front end higher boost , he had it tuned with the stock ecu with the tune stats I posted an has a 12.5 quarter mile printout ,
2 cowboys owned it between him to me, in a 5 month space of time , turbo is high flowed an will handle 18psi but he only ever had it at 11.
so if they didn't mess up to much in that 5 month gap , I'm on a good thing
Nitrous?
Blanked off hole in the crossover pipe would be a sign of nitrous use.
That can flog the crap out of a motor, especially if the timing isnt retarded at least 5 degrees.
Might have got number wrong but he knew everything, he sold it for 7.5 then 2 goon had it in a 5 month period before me.
But from what ultimate told me yesterday it's all there to put down real power. ?
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
