actually a lot of guys including myself add "NOT GTR RX7" at the end, that way its informative and it makes sure someone who searches for a GTR or RX7 sees it.
If you're dumb enough to buy a car off the title, then you're dumb enough to deserve it.
https://www.sau.com.au/forums/topic/43297-dickheads-on-ebay/#findComment-884065
I geuss so the only reason i look at it from that point is,
Before i found this forum i was one of those dumb people who didn't know
Different models to me a skyline was a skyline.
But i geuss it pays to do a bit of research before you buy a car so hopefully
if some one bids on it they know what they are getting.
https://www.sau.com.au/forums/topic/43297-dickheads-on-ebay/#findComment-884074
    • Jax Tyres this Monday morning. Front lifted 15mm Back lifted 12mm Quote1, $175 per tyre + wheel alignment. Quote2, $660 inc wheel alignment. paid $298 for the lot.
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
