I got no idea as I previously stated I take one multi b every morning with extra b6 as well as a op nutrition protein shake as well ( unsure if it contains vitamins ) funny you mention glow in the dark pee as it is almost flouro when it comes out lol
Well I got the all clear this afternoon finally. What puzzles me is I got cleared because what ever substance was in my system was such a minute amount that it doesn't count as a pass. I did bring up the b2 and they told me they were unaware of that being a cause. This incident has puzzled me a lot as of late as my plan is to get into the mines and I don't want any issues what so ever. It kind of making me not want to take as many vitamins/sups even though not taking them seems to affect my mental Heath to a degree
  • 7 months later...
LAWL! I'm not resorting to illicit substances. Alcohol has been working so far - for the last 7 years more or less :)
http://m.washingtonpost.com/news/to-your-health/wp/2014/07/03/psychedelic-drugs-put-your-brain-in-a-waking-dream-study-finds/
Don't say I didn't try to give HONEST advice :P
Just came across that now, and thought to myself "I'm sure I've recommended them to someone on SAU before...." LOL
Read the article though mate, seriously.
oh, and I should've mentioned in my original post that if you're not willing to try something that could potentially help you significantly just because it's illegal, then your issues must not be all that bad at all. No offense intended :)
I've been on anti-depressants benzo and alprozam for the past 13 years now for Panic Attacks, Agoraphobia and OCD, to be honest I wish I never started them, I think that they have made me better in one way but worse in many others, I'm struggling to get off them they are so dependent, I never have energy and the have actually made me depressed and emotional, nothing could upset me before I started them but now I'm like a chick with pms, all in all try everything else first before you turn to them, St Johns Wort work awesome but I cant take them due to the presciption drugs, I'm trying to wean off the prescriptions and get back on the St Johns Wort.
It came down to trying a range of supplements and 'natural' rememedies however all in all the best solution seemed to be having a string network of good friends, keeping myself busy and just trying to maintain a level of positivity. It was tough hut it also snowballed. There are dark patches and I just force myself through it.
Hoffer Osmond Diagnostic Test (Uni Saskatchewan) helps to determine which brain neurotransmitters are running short.
We practitioners assess which supplements support which neurotransmitters and calculate the doses.
Google also doesn't tell you when not to take them and what they interact with.
When it's determined that the above issue is as genetic as it's traced back, we can even announce why it ain't your fault!
So does that also work for panic attacks etc? If so where can I get that test done.
Yes if the PerS scale and DS scale are both elevated and the PS scale is low the client is prone to PSD (panic stress disorder)
I can administer and interpret this Canadian test if you're in NSW.
If in VIC, see Joane Goulding.
You see, there's no blood test urine test hair test or scan that can assess neurotransmitters
Glad to do testing for you! Had several SAUers before.
I'm in Earlwood on Mondays and Fridays.
I'm in Penrith on Tuesdays and Thursdays.
Times are 8.30am till 10.30pm (involving 1 hr consult'ns).
Testing involves one hour only.
Mates rates? Yes, that's fine; because I'm already 65 and semi-retired now > doing this because I love it.
Mob: 0416214699 with preferred time sdtarting at half past the hour.
PS you can click on my website in my Sig if you like.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
