looking for some peoples experience's / price's for 3 inch exhaust's in Brissy area
thanks
I've found the xforce exhausts to be quite good and a decent price.
What are you looking at spending on one ?
as least as possible i guess, been quoted around 1500 up here for a cat back stainless, or 1000 for mild steal just wanted to know what the prices are in Brissy, get back in November, if they are the same i'll just look at ordering one from japan
Are you particular about getting a custom one?
Why not a Fujitsubo, Kakimoto or HKS one? You can get them from a number of places in Japan and install yourself or get a shop to do so.
that's why i said pending on Price, if it's just as expansive for a mild steal as a stainless japanese one i'd go the Japanese, i might just go see some exhaust shops when i get down and see what the quote
I use Rob Bliss in Geebung, Haven't run into problems with them. Got a catback system when i first bought the car then went back a few years later and got them to finish it off. Just got the drump re done at a place in Brendale as I changed to highmount
If you're not too worried about driving a little south (Logan area) Trevor at CES does top quality work. He also offers a turbo back system for R33's. I've had a 3->3.5" custom dump and a custom muffler made, great sound and maximum flow.
yes if i can afford i'd love a CES exhaust on the 260rs, what did you exhaust set you back ?
Ultimate performance exhausts in Brendale to do a good job, I've not used them but A few people I know have any they only have positive things to say.
These guys I'm aware of doing a good job, a guy I work with it's his mates father that runs it. Have only heard good things.
Done at trade price. Rest assured still not cheap but the quality of the product far surpasses that of a cheaper replica. Imho better off saving for longer and just getting the better product. Do it once, do it right.
  • Like 1
I rang around and shop in sumner park has quoted around 450 - 650 for a cat back mild steal 3 inch or 1k stainless
place over acacia ridge has quoted $650 cat back with mild steal or 1100 for stainless
so pretty happy, will go see the sumner park guys as they are closer and get a better idea
thanks everyone for your help
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
