Antilag Racewars 2014 - 12Th & 13Th April, Wyalkatchem Airport
Antilag RaceWars 2014 dates have been released today, it will be held on the 12th and 13th of April once again at Wyalkatchem Airport.
Last year was ridiculously fun and I can't wait to wind some boost up, drop some kilos and better last years efforts.
Anyone else planning on going?
http://www.racewars.com.au/
More power is definitely required, seems I've got some quick cars chasing my title.
650 - 700 Sarah Jessica Parkers should do the trick I think ;)
will be entering
shooting for 650 - 700 whp for the event
hoping the 6 speed gives me a bit more pull in the top end
just booked my accommodation tonight, get on it lads isnt much close by around.
True that, I'm staying at the Dowerin Hotel ~20mins out of Wylie.
haha thats where i booked, ZZM5 has also booked at dowerin Hotel.
however am hunting down a house within close proximity of the track, so if we get house will just onsell the dowerin hotel rooms.
Hi, folks.
I enjoyed myself this year and have a point to prove next year! I have booked my accommodation in Dowerin just now. I hope it is not quite as hot and they iron out the kinks in the schedule. The organisers did a great effort for the first year.
Still learning to drive, it would appear!!!
:blink:
whats the point you wish to prove?
More to myself, than anything else. For lots of reasons, I stuffed up and ran in low boost all through the Saturday. Then on the Sunday I only managed two runs on the 1000 metres, because I was flying out that night and had to get back. The first one, the timing didn't work and I had a good indicated top speed. The second one, I stuffed the start and one gear change and the timing worked. So, I came away with the overall feeling that I had not driven the car to its potential. I want to do that this time.
So that is the point I want to prove to myself.
LOL I no own a 31 , 34 is just about finished :)
Weak :P
I only had the one run at 1,000m myself, I certainly had an average start and a short shift, could have gone faster but doubt I could have pulled up in time, haha!
Edited by Hank Scorpio
1000m = need good brakes.
Got to around 230-240 and felt "pretty" safe with hard braking.
Yeah, I think I'll need my 6-pots for if I ever get to 260-270 :P
  • 2 months later...
Entry is in! Looking forward to it - and hopefully not as much waiting around. But then, that is always going to be the case with an event like this. They do say that in motorsport, one of the phrases often used is "Hurry up and wait"!
Hope to see you guys there. :action-smiley-069:
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
