FS: BRAND NEW set of 18" GL57F pro's (same as on the D1 apex fd rx7 drift car) with NEW yokohama avid S306's.
2 piece rim with noble gold spokes and polished dish. Top of the range lightweight jap wheel.
Have not personally seen a set in Australia appart from these.
The dimensions are F18x8 +37 with 235's and R18x9 +40 with 265's
$4550.
If you are seriously interested contact me on 0403 005 006. (Colin)
Located in Adelaide. Can arrange shipping.
Have put a silver set of these on my silver 34.   Had to wait two months for the wheels but well worth it.  Here's a pic of the gold ones you're selling on a black 34.  Such a nice wheel, good luck with the sale.
Damnn I want these wheels!! they look hot.. my 18" Black Racing Pro N1's will be up for sale soon, if you still have the Gramlights by then I'll give you a call.
:cheers:
Have a set of these in Gunmetal I just about to put on my IS200, sweet rims ;)
  • 1 month later...
  • 1 month later...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
