First thing to do:
timing belt, water pump
Reason why?
Most imports have had their clock wound back, or clusters have been replaced
Then:
  1. Full exhaust (just get 2nd hand) ~$500
  2. Intercooler of some sort, even a R34 GT-t side mount $100
  3. Hit up Toshi for a socketed stock ECU with a new ROM tuned for AU 98 Octane fuel ~$350
  4. Turbotech MBC 0.8bar ~$30
  5. Fry tyres ~Priceless
The only thing I would add to that is a new fuel pump. The second worst thing that can happen to a 20 year old car after a shredded timing belt, is a failng fuel pump.
Edited by Missileman
Johnny's list is solid.
If you want to go further than that you will find out that everything on the R33 has been sized just right for factory output plus a little more. Figure out what your ultimate power goal is and work back from there to see what needs to be done.
This times 1000!!! I spent about 20 grand on mine when I bought it. Thinking back now could of saved a lot of time and MONEY by researching more. I would of saved about 8 grand and over a year of time for a better result.
Ha ha. I also would have saved a bucket load. 3 turbo's before i reached my power goal,
Part of doing timing belt and waterpump is replacing cam seals. They will leak, they cost less than 10 bicks each and you have to take timing belt off to do them, so do then at same time.
First thing to do:
Reason why?
Then:
Who's Toshi? lol
P.S Thanks for the help fellas!
Just a thought, see if you can pick up an rb20det turbo actuator and swap it with the rb25 turbo actuator. I've seen the individual actuators sell for around $50. The rb25 turbo actuator is set on roughly 7 psi whereas the rb20 turbo actuator is set on 10 psi.
Just a thought anyway.
Agreed, mine leaked at about 160k and they were rock hard. Chalk that up as number 6 on the list of things the dropkick knuckledraggers I took it to for the 100k service didn't do properly.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
