Ive searched all day but i always find nistune boards being used. Im from a caribbean island and getting my hands on nistune is hard.
Im changing from a ka24e turboed and chip tuned on a stanza ecu using eprom emulators. So i know my share of rom tuning
Now the question is apart from nistune. Is the z32 ecu capable of being rom tuned using a rom emulator after being wired correctly? I have access to the nistune application but not the boards. So my only option is using nistune's app and a eprom emulator to change the values and burn a chip etc..
Links to wiring info or related info would be appreciated :D but ive found a good amount on info but all related to z32+nistune boards
Edited by Lopin18
https://www.sau.com.au/forums/topic/434410-rom-tune-a-rb25-neo-with-z32-ecu/
Will do if i ever can. But my budget is very small. I got the engine through a friend financing it to me. But so far all the budget will go into mounting it on my car. Im just trying to find alternatives. And yeah im not kidding. 500us right now isnt available to me any time soon.
Hmmm indeed, but this is a 6 month engine project as the drifting season is off right now here so its covered. Im just trying to find an alternative for the tuning part which is the one not defined on the plan. If its doable ill try it, if not ill have to delay and get nistune in the end, but if possible id like to try out the z32 option. Sadly as you guys noted, Nistune is the way to go, and seems like very few people have tried the other way.
Supposedly the Z32 can manage the VTC of the Neo, Its a 8 Bit ecu so you can chip it and run a rom tune.... or so goes the idea. Also people usually get that one to run Nistune.
Ill just test using the Z32 with the local tuner, if things get complicated ill just delay the project and get Nistune for the Z32 ecu and RB25, but i have to inquiry now if i should use the Type 4 board on the stagea ECU, or the Type 2 board on the Z32 ecu. But ill go to the nistune boards for that one.
yes. the z32 ecu can be tuned with a emulator. i was just emulating one 10 minutes ago.
use the file
Z32_FOR_RB25_41P03_MT_v2
in the nistune rom pack in the type 2 folder
but how are you going to plug the z32 ecu into the neo loom? are you going to re-wire the ecu completly ?
let me know if you need any help.. ive done quite a few of these.
my skype is anthonye1978
www.facebook.com/tunedbyanthony
cheers
This is true but most people do that for normal rb25's as there isn't a nistune chip to suit the rb's from r33's. There's a nistune chip that installs directly into the nistune computers though
Use the Neo or Stagea ecu - it will run the vct for you - as Marcus was saying people only use Z32 ecus on R33s because there is no Nistune for R33
  • 4 months later...
After many months reading diagrams, confirming ecu pinouts, cutting and soldering wires, i finally completed all mechanical work today got to test my Z32 adapted wiring, after changing the fuel pump relay it was an instant start.
I had a Stagea RB25 Neo, with its wiring loom and i used that one. I cut the stagea plug and rewired the ecu plug to the R33 plug & pinout, almost all important wires have the same name in the R33 just different positions. Then i changed the R33 pinout to Z32 pinout, which had minimal changes in positions, switched the CAS wires to the new layout that the Z32 uses and followed Nistune's guide to prepare a Z32 ecu to work with the R33 rb25. Worked the usual ign 12v+ wires, battery 12v+, grounds, etc and that was it.
Currently running the Z32 ecu with a Moates Ostrich 2 with the file mentioned by GuiltyToy "Z32_FOR_RB25_41P03_MT_v3". Now to put everything in its permanent position and tune it.
Its a cheap way to do it, but it was interesting and i learned a lot. Its an option for those who cant go the full mile.
Edited by Lopin18
f**k yeah!!! well done mate!
thats an awefull alot of trouble to go through for just a eprom z32 ecu :) when you could have just nistuned your ecu for about $200 :)
there are plenty of ways to shoot yourself in the foot :)
wouldnt mind seeing some pictures of the wiring job and of the car... very interested.
Yeah i know, but ive always liked trying things out and since i had some months free until the engine's swap work would be completed i took this option. Also many RBs here in my country are using Z32 (many of them dying for some reason unknown, probably our horrible gas or something being wrong with their z32 setup) since this is a third world country i knew that if i made it work i could help others here.
Soooo this is pretty preliminary, ill attach what i used to understand and do the wiring, dont take it as a 100% guide since after i printed these pages i did the wiring, they are all marked and dirty etc but ill be busy for some time now that the engine is on and i have to test and check everything, someday ill make a nice guide confirming everything if needed (i know the pinout references are ok, but the power lines and ground lines you have to think about them):
- These two pages are the resume of what i did on the pinouts, one says which pins came from the stagea plug and where they went in the R33 plug, the other page then says from the R33 to the Z32:
Edit: I think there were some pins i didnt write.... confirm all pins with the Pinouts below.
http://i200.photobucket.com/albums/aa189/Lopin18/20140315_105611.jpg
http://i200.photobucket.com/albums/aa189/Lopin18/20140315_105621.jpg
And these ones are that i used to make the pages back there, ugly as hell but oh well, the original diagrams are around found in google very easily.
There are many pins i didnt use, this is a drifting car so i ignored a lot of stuff from Air conditioner etc
This pinout shows on pencil where each pin goes to in the R33 plug, affirmative marks just mean its the same pin in the r33
http://i200.photobucket.com/albums/aa189/Lopin18/20140315_105638.jpg
R33 pinout, shows on pencil what pin from the Stagea plug goes into each pin
http://i200.photobucket.com/albums/aa189/Lopin18/20140315_105731.jpg
Z32 pinout, says on pencil which pin from R33 goes into each pin
http://i200.photobucket.com/albums/aa189/Lopin18/20140315_105749.jpg
And finally the Stagea wiring diagram, i marked in yellow the wiring to be done outside of the plug, which are all the 12v positive wires and grounds, so i could make sure i had power everywhere and ground just as the diagram says for any future troubleshooting.
http://i200.photobucket.com/albums/aa189/Lopin18/20140315_105807.jpg
Original size of the images available here: http://s200.photobucket.com/user/Lopin18/library/
And for consolation, i didnt study wiring etc, i once checked my KA24 wiring with the FSM and decided to shorten it and check all wiring, then i took this stagea thing into my hands, so not a wizard here, i learned by logic and by reading the diagrams and seeing the wiring loom in person along with a tester to see which plug, line, pin etc went to and came from.
Edited by Lopin18
Just for the record, Fixed the consult. It was a cut track on the board damaged from the rom chip work. Every is working perfectly now.
Well done! I'd say you could get plenty of work in Aus or NZ sorting out people's wiring.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
