Hi Everyone,
I'm relocating from SA to Springfield Lakes. Can you help me with a suggestion of where I should go for a RWC and mod plate?
In another thread I was told my car looked low and that the cops would pull me up straight away. I believe my car is standard height and it's the illusion of the kit that give it the appearance of being low.
Here are the photos I took for the transport company
I can get 2 fingers in between the tires and guard front and rear. Is it too low?
Any help would be appreciated.
Cheers.
space between guards and tyres is not an issue, as long as the lowest point of your car (including the exhaust just near the diff) is above 100mm
What parts of the car need to be mod plated?
Everything is above 100mm (when checked on level ground)
I have no idea what needs mod plating (because I'm not familiar with your regulations)
My list of mod are:
Secured Apexi pod (not in a box)
z32 AFM
hard suction kit
T04 Turbo
Stainless ext. manifold
Turbo back ext. with hi flow cat etc. Not loud
Manual boost controller (22psi)
FMIC (metal was cut to accommodate the piping to the throttle body)
After market BOV that is 100% recirculating
Q45 Throttle body
Freddy forward facing intake manifold
1000cc injectors
Top feed fuel rail
Turbo smart FPR
Walbro pump
RB20DET ECU with nistune, running E85
permanent wideband lambda, boost, temp gauges to DLP-I08 and Consult
I think that's about it
You will need a mod plate for the turbo at the very least and the hole for the FMIC will probably need to be certed as well, as for the rest I'm not sure. The reo being cut will be a defect if it is found and can't be mod plated.
I know of a mobile mod plate guy on the northside but I'm not sure how far he roams to plate cars. As everyone said keep your SA rego until you have everything up to scratch.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
