I've managed to secure the following brake kits, due to arrive in 1-2 weeks. All are in good condition and are a straight bolt on for R32 and R33 Gtr (plus Silvia and R31).
Set 1: sold
Set 2: $SOLD
Set 3: $1350
Grex (Alcon) 4 pot front setup 332mm. Includes rotors, calipers, pads and brake lines.
8.7mm of pads and 31 mm thick rotor
Set 4: $1300
AP Racing 4 pot calipers, 324mm rotors, pads and lines.
pads have 12mm of pad each
rotors are 30mm thick
Pick up Lower Blue Mountains Sydney or can post at buyer's expense.
Pete
https://www.sau.com.au/forums/topic/434418-fatz-big-brake-sale-grex-ap-racing/
  • Replies 42
Oh man, I've only JUST had some 32GT-R brakes installed on my LOLvo, and am waiting to get it back once the other work is complete. Timing, hey?
  • 3 weeks later...
Pics of the stop techs fatz please?
Would there be any gain over the gtr brembos in performance? Can they take a bigger rotor?
Cheers Josh
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
