Hey all, I'm bored at work so I figured I'd make a little build thread to document my new 32.
Here's how it sits currently (Got new black plates though which look 1001234500101 times better)
Little run down off the top of my head what she's got on her
Exterior:
Panasport G7 C5C 2 17x9.5 all around (I THINK)
215's on the front, 225's on the rear
Ganador side mirrors
Genuine GTR bar and lip
Genuine GTR front guards
M-spec side skirts and rear pods
Rear roof lip
Blackedout headlight surrounds w/clear indicators
Interior:
GTR front and rear seats
HKB boss kit w/ Auto Platonium steering wheel
Speco boost gauge
GTR center gauges
External MSD VCT controller
Engine etc:
Series 2 RB25DET and gearbox
Heavy duty Exedy 3 puck cushion button clutch
HKS 30/37 Pro S
SARD 550cc injectors
Z32 AFM
Nistune
Front mount
3" turbo back exhuast w/ cat and rear 5Zigen muffler (could probably fit a small child inside the outlet)
Splitfire coils
50mm (I think..) alloy radiator
Suspension:
Tein superstreet coilovers
Has got a lot of adjustable gear underneath but I haven't looked at what the brand is (they're all blue though..)
Hicas lock bar
https://www.sau.com.au/forums/topic/434649-bilsons-32-gtst/
Car was tuned by no other than DVS JEZ who managed to pull 307kws on about 18psi outta her
When I first bought the car I was a little concerned about running this sorta power on a daily but my mate I bought it off had been doing so for over half a year with no problems at all and I trust him and I trust Jez's tune.
But fuuuuuk she was a beast to drive.
So when I first picked her up the speedo didn't work due to the 25 box in it so I went ahead and ordered myself a new navara speedo drive from my parts guy at work, went and bought a little blow torch from bunnings and within the week , voila speedo!
Random chills
Brought it into my workshop a few weeks after owning it and did a full service on it pretty much, tried out a 15/50 nulon fully synthetic, genuine nissan filters, gearbox and diff oil. About a month later I assumed the 25 in her would be pretty much on 100k, so apart she goes, new timing belt, tensioner and idler in, new coolant and she was swell. Should have taken more pictures.
But I blacked everything whilst it was apart
https://www.sau.com.au/forums/topic/434649-bilsons-32-gtst/#findComment-7098747
Then one day it started smoking when it came on boost, like bad.. filling the cabin suffocating smoke bad.. I checked the oil and coolant levels and the oil smelled like burnt dick so I figured I'd change it and try another oil to see if it made a difference. Sort of toned it down a little, sort of. But then I took it out for a drive that night, hit boost going up a hill in 3rd, started sounding like a harley, spat the dip stick, spat oil everywhere, game over hahaha.
So currently in the process of sourcing a new 25 to go in it as I just want a quick and easy fix cause I want it back on the road ASAP and dont have time to mess around building it and shit, I am just that stubborn.
https://www.sau.com.au/forums/topic/434649-bilsons-32-gtst/#findComment-7098771
Got a box of presents the other day, just building up the things I'll need when this I pick this new engine up.
Just got a genuine oil filter, spark plugs and a new nismo reinforced clutch brake, as mine is held in place with rivets and is bent sideways which pulls the speedo cable out of the cluster if you aren't careful, which is annoying. Looks to be a really back breaking job that I dont really look forward to.
https://www.sau.com.au/forums/topic/434649-bilsons-32-gtst/#findComment-7102897
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
