ok so i hate to do this but I'm starting to get desperate.. :unsure: i have a car that needs pit passing as it come from the nsw I've taken it to a few different places and they have all said the same to low window tint to dark i need some one that is easy going on rego inspection the car is in very good condition inside and out has few things that i worry about has adjustable arms from and rear screamer pipe its low but not over the top would be 100mm from lowest point car looks very sleeper from out side I'm willing to travel to get inspections so please help a mate out I'm sure someone out there knows of some one that would do them
pm me :rolleyes:
  • Like 1
https://www.sau.com.au/forums/topic/434897-help-me-get-my-car-pit-passed/
pm me :rolleyes:
Tint that's too dark, a screamer, and 'not too low' but is 100mm.... Which is about the depth that the open class WTAC Winnig gtr runs at....
It's usually the easy to change and obvious things that can't be ignored that are hardest... Like dark tint and low. Surely you get the point after a 'few' different places say the same thing. you're asking someone to risk their operating license.
Sorry what I ment was window tint that is still legal and it is well over 100mm from the lowest point of the car (as apparently that's the rule?) and if I do lift it up change the wheels pull all the adjustable arms out source stock ones and do 100other things there still no doubt going to fail me on the screamer that are things that are a lot harder to change when I'm sure there's someone out there that would sign the car off as it is..
Sometimes those costs have to be factored into the 'cheap' mainland cars unfortunately.
Goodluck.
By the sounds of things, no mechanic would/should sign off on it as is and as stated, they would be risking their License to do so.
Sometimes you just have to play the game. :yes:
Dont just weld the screamer up, if you hit gate you will create all sorts of dramas as the gas will be pushed backward. This could damage the wastegate / turbo.
Get someone to extend it and put two flanges on it, so that it can be recirculated into the dump pipe, and removed. Cost you maybe $100
Oh no no I wasn't thinking of welding it up and if I did block it up I wouldn't even think about going any where near boost like just have it like that to drive to the inspection and drive home but I have a guy that is good with fab so I'll speak to him about plumbing it back in to the exhaust and make it so I can switch between plumb back and. Straight out
Best bet would be to get it plumbed back into the exhaust, I had it done a few months ago on my R32 due to the obnoxious noise when on boost and all the unwanted attention it caused. Cost me $200 to have done.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
