I need to smooth out the gutter etc to get the GTR in without lip damage. First quote is $1900 incl delivery and GST for 2 off 1.5x3meter 12mm plates. Does that sound reasonable price and thickness wise?
https://www.sau.com.au/forums/topic/434939-metal-plates-for-driveway/
just use wooden blocks. 50 bucks max. sand/plain them back to shape. waterproof em. will last years.
Holy f**k do you know how heavy that thing will be?? Your gonna need a forklift to get them into place.
Post some pics of the driveway.
@ Terry - ill give Sims a call. Any idea how many mm think yours are?
@ battery - Yeah i know forklift required.
Wood? Meh. I'll spend some time to work out how much shorter i can get away with - I imagine the angles are in a non-linear relationship with the plate length. Just need to remember how to do trigonometry...
I'll take my vernier down Adam and measure it tomorrow
I opted for 2 plates because when it rains, the muck goes underneath.
Cost was about a grand I thought including drop off and placement. Then came the hole drilling and insertion of Roundhead bolts.
this is all too extreme, i encounted this problem also where my driveway, dips down where the gutter is. and ripping my 32 gtr spoiler off neally everytime, so i found abit of old checker plate steel around 8-10mm thick brought it home, cut it to the size i wanted, approx 1200x2000w i then welded to steel angles to the underside 65x65mm length ways roughly were the wheels go over the plate. also welded 2x 16mmx65mm dynabolts to the under side of plate,either side where plate sites on the tar. then drilled). water still flows underneath, has held up for the last 12months since i installed it, and has withstood my 9 tonne work truck driving over it numerous times. cost me $0 and took me around an hour. can upload pics if needed? can also help you if you need? i have a truck a hiab, and work with steel all day. just need to locate steel. (scrap yard) inbox me for details
Lee - where did you get the check plate? I have no oxy or welding equipment, so I'll just have to spend the money. Unless i can find a better option i'll probably just go for 1 off 1.5x3meter 12mm plate to halve the price, or maybe see if the supplier can do 10mm in the same size. I sometimes have semis parked across my driveway....hopefully they wont bend it.
More than 8mm will be a must then.
It'll be great if you can access the steel cheaply!
Once laid, we also slotted a couple of coach bolts with sleeves (some way along the plates) so that trucks wouldn't bend the plates.
i work in the roller shutter industry, and took down an old sliding gate, that someone had welded the piece of checkplate too, so it was just by luck mate, but there are cheap ways around it. i personally have no access to plate steel in that size, but would recommend giving sims a call to see what the would charge for an old piece, or a local steel supplier. thats why i welded 10mm 65x65 angle underneath, where the low points are to stop any flexing or bending under load. as i said mate i have a truck with a hiab, welder,grinders,oxy and am more then happy to help you. just need to locate some steel. i have access to smaller bits for strengthening underside etc. just let me know mate.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
