Fs [Syd]: Genuine Recaro Sr3 Bucket Seat With Bolt-In Low Rails For R32/r33/r34 Gts-T & Gt-R Minus Gt-T
R34DE as in R34 with an RB25DE? So did you get this? Or you planning to? I'm not really sure what you're saying.
