NiSSAN SKYLINE R33 manual TURBO PARTOUT!!!!!
5 speed manual
Rb25det motor $1500
5 speed manual gearbox $1300
rear taillights $100pair
complete bootlid $100
Front mount intercooler $200
oem smic with piping $100
brake calipers $300 or can separate $200 fronts $150 rears
or with complete 5 stud conversion
radiator $100
r33 gtst diff $200
half shafts $100
stock standard suspension $100
factory oem side skirts $150
factory oem rear pods $50
400r side skirts $100
rear bar $100
3" exhaust from turbo back $300
R33 factory wheels $150
front bar reo pefect condion $100
doors $150ea
rear skyline oem strut brace $100
volk racing wheels R17s $200
headlights $100 ea
Bonnet $150
front bar $100
ignition barrel with key $150
for any other parts call or text me on 0432-062-780 located in Melbourne
https://www.sau.com.au/forums/topic/435277-skyline-r33-gtst-partout/
ill give ya 20 bucks for side mount if your in south east melbourne?
please dont be offended by "low ball" its just the going rate, unless its a 34 smic?
iv sold all my smic for $100 ea in the past so ill think ill keep it the same price when ppl get defected man or returning the car to stock trust me they buy it
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
