  • 3 weeks later...
  • 3 weeks later...
lol its been a long ride boys & girls though things are getting a lil off track for the time being
I would not of missed any of it for the world all the great people I have meet & every thing that has gone on.
I was on SDU to start with too I was very very shy back then & keep low still do sorta as well today, but being old school means that every ones sorta seen me lol
man I didn't think it had been that long I been here from may 02
good on ya prank & every one for bring us this far :D
Still a lot of us old skoolers around which is good, my old gtst is still shown in the aussie owners ride section of SDU (I was Blue Streak on SDU).. I searched SDU not long ago and found WA's first cruise thread from waayy back in june 2001... I still remember that cruise too, think we had about 6 lines back then turn up, never saw any on the streets either!!! ha ha
Great thread funky.. :)
Cheers
Brett
  • 1 month later...
Hey, good read, now all i've got to do is find my old 360dd posts in a row in the popular post whoring thread. Havn't been round for a while cause i sold the skyline and moved to canada to snowboard. Loving the snow boys...Hahaha.
And would someone smack porgie and get him back, slack prick. Come in charlie, do you copy ?
  • 4 weeks later...
Nice to hear that there are so many oldschoolies here, i am from the new school back in 2002 i knew nothing of skylines, now thanx to all the members here i have an understanding of what to look for when i buy a skyline.
All the technical knowledge you guys have is still a little overwealming but i will learn in time.
thanx for your help
  • 6 months later...
I don't know if i'm old sckool enough but Shell sent me SDU sticker from NSW, back in the day and yes same story, i got a pm from someone asking me to join SAU.
Edited. Just went back and acctually found my old pm from Shell,
Re: SDU sticker please!!
Babes, you need to tell me if you want a white one or a chrome one.
white = $8.30
chrome = $12.30
Front or rear doesn't matter, they're all one size.
Let me know which one you want, and I'll send it off to you straightaway!
cya!
Shell
This is like back in early 2002 and i think i joined up with SDU since late 2000 or something like that.
  • 3 months later...
Funny how the kick-off of this forum in 2002 is considered "old school" LOL !! I can remember signing up with the NISSAN SVD Car Club back in 1995 with my HR31 GTS-X. :lol: That was when an R32 GT-R would set you back $110,000 :P
Back to the subject at hand though....... SAU = Great forum !!! Cudos to those responsible.
  • 6 months later...
  • 3 weeks later...
  • 5 months later...
  • 4 months later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
