* Rosberg got a really good start jumping both Dan and Hamilton
* Kobiashi locked all 4 and tagged Raikkonen and then rear-ended Massa
* Hamilton and Vettel retire within 5 laps
* You couldn't hear the cars leaving the line over the commentary :/
Edited by chus13
Need break down of start pls
romain to start from pit lane, got a penalty straight away for leaving garage too early
two aborted starts each for marussias
off the start kevin nearly loses it off the line, rear steps out, nearly wipes out alonso
kamui locks up, takes out massa and taps kimi i think
lewis told to retire, then not, then actually retires
vettel complains for a while about no power, then retires
hulk passing heaps of drivers, same with bottas
bottas following alonso close taps the wall where rachael finch rolled over
sheered the wheel rim and had to pit
safety car out to clean up the tyre and wheel rim on track
now reports of a bit of rain
Edited by MatthewT85
