how funny was it listening to Louise stress out towards the end. Your car is 3 sec a lap faster and you'll be coming out on brand new tyres compared to the others on dead tyres. It was never going to matter where you came back out after the pitstop ffs.
Was also interesting to read Vettels comments about how he thought it was odd-risky for Homo to overtake him where he chose to rather then wait one more corner and a straight...Vettel said he had to kove over for him so to avoid risk of contact. Seems Homo just likes the drama
Would be shit for it to be decided at the last race because of the lame double points nonsense.
Also:
Ferrari have signalled approval in the past for the prospect of running a third car, and their position remains unchanged with a spokesman saying:
“It’s not about the survival of Formula 1, but for the show. With all due respect, people would prefer to see three more Red Bulls, Ferraris and Mercedes than the other cars.”
Well, I for one wouldn't. Would rather see the midfield get enough coin to be viable. Time for Ecclestone to sod off and sit in a retirement home somewhere.
Edited by djr81
The stupid thing is that 14 points between 1st and 2nd at the final race means that there is a very strong chance of whichever Merc driver wins there will win the championship. Imagine if you are Homo then going in with a 12 point advantage and way more GP wins then anyoen else this season and you dont win the WDC. Its pretty silly.
It is rather shocking the reliability issues the Mercs are having. They are worse than RBR, McLaren, Fezz, Williams, FI etc when it coems to mechanical retirements. Good thing they are so damn fast.
Pulling out a 25 second advantage on used tyres over about 10laps is pretty clear indication that they enjoy a huge pace advantage
Vettel should have done the team thing Singapore style and taken out Hamilton while he was going for the overtake.
Then, Dan would get the win and with both Mercs out it would make the wdc more interesting ?
Edited by mickey
either that or everyone else was right... which the court process proved anyway, remember...
If they were really steaming pieces of shiza at the start of the season, RBR would have been able to prove that in court. Instead the full decision of the appeals court says:
As evidence of the reliability of its fuel flow model, the Appellant provided a series of graphs...Several graphs actually showed that parameters had changed from one lap to the other and that one cannot, therefore, conclude that the fuel flow model did not change notably... On top of this, it appears that not all parameters... were shown in the graphs
That was Red Bull's "proof" - doctored graphs and refusing to fully disclose the parameters used to esitmate fuel flow in their model!
The meters were fine.
Edited by hrd-hr30
LOL, meters were rubbish but other teams had the same problems, but they suffered in silence and went with the proper procedure. RBR picked a fight and didnt follow the correct process and got burnt.
RBR doing a hatchet job over the politics around the faulty meter doesnt mean the meters were not problematic. :) Says I :)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
