  • 1 month later...
So after getting the car running we ran into some more wiring gremlins. In the process of re-wiring the motec and engine bay harness with a new firewall plug etc.
On another note I'll just leave this here..
I'm pretty sure looking at what's out there and the cost people want ill end up making them myself.. It will be the rotors that are gonna be the hard part
Edited by johnbarry88
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
