Hey I am new to the skyline world. So I went to mr minit in sydney to get a spare key cut. After scanning for an imobilser chip the guy said I dont need the chipped key. So I got a key cut fot $10. I havent tried it yet. However does this sound right? Will it start?
Thanks in advance
https://www.sau.com.au/forums/topic/435590-v35-300gt-key-question/
I don't have a 300GT, but I would be surprised if they don't have the same NATS system as other V35s. see if it starts the car. If the engine just cranks, but doesn't start, then you need a chipped key.
My 300GT is a P Collections and it has the factory immobiliser and transponder key. I had Mr Minit cut me a spare and they tried to "detect" the transponder but were unable to offer a replacement. The car won't start with the cut key, just turns over. I presume this is the same NATS security that the 350GT versions have.
I doubt it, probably just a factory upgrade. Nats is built into the ecu/bcm, perhaps it's more the bcm that does it, or just the factory alarm you have.
I haven't heard anyone of this forum discuss their V35 having "factory alarm" without it being a NATS.
I have the usual windows label, the flashing LED labelled "Security" on the steering column, car turns over without starting when using cut key etc.
Chris Rogers wrote in his V35 FAQ on immobilisers, "all of them have a factory one and that it is not compliant with insurance nor OZ stds ADR 82/00. Exception is the M35 Stagea"
Its not a requirement of importers to remove the factory immobiliser in NZ.
there is a factory or dealer 'alarm' option which is in addition to the standard NATS immobiliser. Not sure if it can be fitted to a 300GT if it doesn't already have NATS.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
