Hey guys,
Reluctantly selling my beloved 2 door, manual, 1990 Nissan Skyline R32 GTS as I am pursuing my studies again. I am the third owner of this vehicle and have wined & dined it as it is and has been my pride and joy. The car is in good condition inside and out considering the age and is currently at 221,306kms, has never missed a beat and regularly serviced every 5,000kms by Chasers Motorworks with 4100 Turbolight 10W40 Engine Oil. Only fuelled with BP Ultimate 98 Octane Petrol. Registration until 1st June 2014. The engine has been swapped from the original RB20DE-T model to an R33 Skyline RB25DE NON-TURBO (P Plate legal) twin-cam making roughly 140kW, Six cylinder, 5 speed manual gearbox and has been registered to the car by VicRoads.
Minor mods include:
Fully adjustable HSD HR Coilovers which were fitted roughly 20,000kms ago
6000K HID Xenon Headlamps
Mongoose Alarm & Immobiliser
3A Racing Pod Filter
Front Strut Brace
Exedy Heavy Duty Clutch
Remus 2.5inch Catback Exhaust
R32 GTR Wheels 16x8+30, 225/50/16 Tyres
Kenwood Head unit, 2x 6inch rear splits, 12inch Subwoofer & Amplifier
M-Spec Body Kit With N1 GTR Front Bumper and GTR Spoiler
$11,200 with Reg until 1st June 2014, RWC can be arranged for additional costs.
Located in Western Suburbs
Very enjoyable car, will not disappoint.
Contact me on 0432288280 if interested, no time wasters please.
Edited by RoyceR32
Just because it has a non turbo engine swapped into it, does not make it P-Plate legal!
The car is still a turbocharged vehicle to the police/ authorities and you will cop the penalty for driving it, regardless of what engine has been put in.
Not trying to burn your ad, its a nice looking car but some poor kid could loose his licence over it.
Edited by Bennis
:/ You can get a GTR for that price...But yes. Still can't be reg for P Platers.
It's P-Plate legal in WA, mind you at ~$12.5k landed here that's a lot of money for an N/A R32...
  • 1 year later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
