yep kind of looks that way...guy buy stuff off ebay, realises it needs some major tuning and gives up on it...
please dont say its running a stock ecu....
It's an awesome microtech bro!
must have a seriously big spring in it if it wasnt opening before...
There was no vacuum/pressure lines to it before, so it wasn't opening at all, nor was it controlling the boost as he has said.
Now he connected it up by running vacuum/pressure lines to it, and it is opening, but dumping straight to atmosphere.
  • Like 1
No pressure source, it won't really open.
My 14PSI gate won't open without a pressure source on it.
And I'm betting it's a stock ECU... Since everythign else sounds stock...
Oh god... A microtec...
Pull your ebay turbo off, pull the looking like aftermarket manifold off.
Shove it and the microtec on ebay.
Buy a standard exhaust manifold, and purchase a stao high flow with Adaptronic ECU.
Reliable turbo, fixed up exhaust system + decent ECU all done quickly and easily.
Don't waste money tuning it twice.
  • Like 1
Oh rajab... A microtec...
probably the most solid advice i've heard. Waiting for money to come in before i can make such a drastic build though, baby steps. Any suggestions on turbo models for rb25det?
Edited by iTwix
Lets pretend you didn't ask that, to save more flaming.
Read up.
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/
As per the original post & subsequent post relating to '2007' rego sticker on the windscreen, as mentioned, I hope your for your sake & the rest of us enthusiasts here that you actually have registration & insurance on that thing...........
are you srs.. :| Ofcourse it's rego'd w/ insurence. -.-
plumb the wastegate back into the exhaust and it will be quiet again, are you running a stock turbo cause it sounds like it..
LOL
Seriously you put a screamer pipe on your car and are wondering why it is too loud? Maybe the above suggestion is a good one.
edit: You drove it without the wastegate hooked up? You are lucky you still have an engine, surprised it didn't blow up from overboosting, you need to get it tuned asap because it could be pinging it's tits off.
edit2: holy shit you don't even have a screamer pipe you were just venting it open in the atmosphere??? Suprised you didn't cause an engine fire, you've probably destroyed all your rubber hoses now. Stop driving the car!
microtech lt-12
Worlds worst ECU, get a stock ECU with nistune or something half decent.
Seriously save up a few grand, get the wastegate plumbed back into the exhaust, then get a proper ECU tuned, if you haven't already you WILL destroy the engine and your engine bay driving it like this.
Counting down the minutes until you burn the car to the ground or put a rod through the block, can't be more than a week away now.
How did it pass RWC in that condition??
Edited by Rolls
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
