OK so i have aborted my 32 GTR build and have thousands of dollars worth of parts brand new and used...I have receipts for the brand new stuff mostly purchased through Godzilla motorspots.
The following parts are brand new!!
Hi Octane alloy sump kit - $800
Nitto oil pump - $1300
6 Boost RB26 mani - $1250
6262 precision BB with oil drain and V clamps t4 split pulse - $2000
D2 front brakes 356mm 8pot, with lines etc for 32 gtr still in box - $1800
D2 rear brakes 330mm 4pot, with lines etc for 32 gtr still in box - $1800
both sets of brakes were bought in group buy...
HKS EVC 6 boost controller - $600
Torque split controller $150
HKS turbo timer $150
PWR intercooler built to order $1100
DO-LUCK Rear Cross Bar 32 gtr http://www.rhdjapan.com/do-luck-rear-cross-bar-nissan.html - $300
BC BR series coil overs 8kg front 6kg rear still in the box - $1100
Used parts
Greddy polished plenum with 90mm throttle - $1100
Trust oil cooler with braided lines and Earl fittings - $300
Massive polished ally catch can sits where the battery is located and rad reseviour with black braided lines and fittings - $400
Grex oil sandwich plate - $60
OK i have the mother of all rb26 heads built to make big power! assembled by Godzilla Motorsports, Supertech and Tomei EVERYTHING I am not letting this go cheap so don't try and low ball me
extensive porting
1mm+ oversized intake and exhaust supertech valves
Supertech double valve springs
Supertech bronze valve guides
Supertech valve stem seals
Supertech titanium retainers
Tomei solid lifters
Tomei 270 by 10.25 cams
$6000 cost me more with cost of head and work done etc it is precision workmanship.
Located in Brisbane 0421883199 only serious buyers no f**king around serious money here...all i can think of for now may add more, as i have stripped an RB26 and have lots of spare parts. photos up soon
https://www.sau.com.au/forums/topic/436119-eoi-massive-gtr-parts-sale/
updated list
PWR intercooler built to order $1000
DO-LUCK Rear Cross Bar 32 gtr - $300
R34 gtr crank - $350
Brakes are the same colour backs are just smaller...
Edited by lilley's gtr
What are you asking for this???
extensive porting
Tomei solid lifters
  • 2 months later...
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
