Rb25det gearbox and shifter $1000
Rb25det r33 r34 manual conversion kit comes with everything $1350
Haltech Ecu with wire in harness comes with map sensor etc $750
Splitfire coilpacks to suit rb20 rb25 rb26 $330
R33 s2 headlights pair $250
R33 Gtr strut brace $50
R33 sedan aftermarket sideskirts $80
R33 door cards $10 each
R33 drivers 12 pin window switch $50
R33 bonnet $100
R33 front Reo $70
R33 front crossmember $50
R33 genuine rear pods $40
R33 genuine sideskirts $50
R33 fibreglass Gtr front bar needs repair $50
Rb25 neo Superspark coilpacks $250
R34 gtt coupe rear seat $50
R34 gtt sedan rear seat $50
R34 gtt front seats $90
R34 xenon passenger headlight mint $300
R34 rb25det neo engine harness $150
R34 ignition barrel with key $100
R34 coupe boot carpet $20
R34 radiator $50
R34 air con control $50
R34 centre gauges $50
R34 rear parcel shelf $50
R34 coupe door trims 30each
I have many other parts left from r34 gtt coupe r33 gtst r32 gtst
Nerang
0487924497
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
