A few random parts sitting around, all located on the central coast, or once I return to work in the new year I can possibly deliver/meet in hornsby area. Id like to avoid postage just due to time constraints, small items I could be be open to postage never hurts to ask....
open to offers but most things are pretty cheap already, I can only say no, feel free to ask questions.
r33 gtst turbo with blown front bearing. $30
also comes with both std manifold and turbo heat shields with brackets
has a r34 elbow that I had leftover
solid factory oil/water lines $30
have a few different banjo bolts and stuff I can throw in if they help you out
complete set of std 33 series 2 injectors, replaced with larger at 90,000Ks
$50
SR20 sandwich plate, 2 x sensor holes $50
r33 series 2
drivers door trim few small marks on the material section but otherwise schmick $20
rear seat side trims, schmick both for $20
std silver wing mirrors removed to fit aftermarket ones, both completely schmick $30
also have brake and clutch pedal rubbers removed to fit vspec pedal set, $free
Original r33 series 2 lip $30
has damage as per pics, I replaced mine with a new aftermarket one. original std silver
post-26316-0-92143900-1388459118_thumb.jpgpost-26316-0-27303900-1388459129_thumb.jpgpost-26316-0-74233200-1388459138_thumb.jpg
Std series 2 fuel pump $30
replaced with larger bosch, about 90,000Ks on it
Hicas unit series 2, removed for lock bar $10
I think this is a q45 throttle body with tps $30
Std rubber brake lines replaced with braided lines $30
a couple of braided lines leftover from other stuff Ive bought over the years, app & brakequip brands $30
Origin under lip canards, never used or fitted one still in bubble wrap how it arrived from japan.
$100
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
