Interested in swapping your -7's for my -5's? Not sure what condition mine are in because i bought my car with them already in, but happy to make a decent cash adjustment if they are in poor condition.
Let me know via PM Thanks :)
Lastly, on the CES dumps/fronts, would i be right assuming they are the "Standard" as opposed to the "Competition" (longer) dumps?
and so the front pipe would marry to a 3" catback?
Yup they're the std dumps, and the front pipe has a 3in flange for marriage to a 3in cat and an of the shelf cat back exhaust...
  • 4 weeks later...
  • 4 months later...
Sorry to bring up an old post. Has anyone gone to see/pick up parts from this gent? I purchased the front pipe off him In February and still haven't seen it yet. Tried all contact methods and haven't heard anything from him. Wont pick up calls, reply to sms's or reply to pm. Thing is, he sounded like a genuine guy, so not sure what the go is to be honest. Hopefully someone knows the guy. Sent a Moderator a pm about it, and haven't heard back from him yet.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
