Invoices go out on Saturday. Pay have and follow the instructions on the invoice please. I have no way of tracking these without the invoice number.
Can I get a rundown of the GPS Tracking + Paging. What Sim Card to buy, $30 dollars that is unlimited time or what? How does it all work? Does it use Google maps or another program? How accurate is it and how quickly does it refresh?
Since I've received my invoice but you haven't replied to my message. I'd also like to know how warranty works? Hypothetically what happens if the unit shits itself within the first or second week? Who repairs it and at who's cost?
Cheers,
Borci88.
SIM card , Telstra do a SMS package that debits your bank account. You need that one. Vodafone also do them. $5/ mo or so.
Warranty taken care of by the local dealer there. Warranty work won't be required though as these do not break :) regular maintenance on it though will be required. The pin switches do corrode over time. The rest though is solid.
If you have questions - call me. I'm not on here daily as currently I do not get time to.
I average 100-200 calls a day and barely get time to get jobs done. (Phone is getting set to divert once this trip starts)
Email is the other way to get me.
23/01/2014 Direct Credit JONATHAN NGUYE N Jonathan5793 $377.00
23/01/2014 Direct Credit SEBASTIAN GIUL IA Sebastian 5790 $344.50
23/01/2014 Direct Credit MY NGUYEN Eric Tchung 5788 $754.00
23/01/2014 Direct Credit TIMOTHY MUMFOR D mumford 5787 $690.00
23/01/2014 Direct Credit SHIVAM ROHIT Shivam5791 $659.00
Missing 2 . I know why I am missing one of the two what about the other.
Stock organized btw. Did so Friday.
emailed (got busy)
Stock here - ships monday.
updated list.
29/01/2014 Direct Credit ALVIN SIEW xALmoN 5789 $400.00
find your postcode. some of those left today some are going in now.
the two honda guys. going to do OEM locks on yours as well.
is this your car?
1998-2000_Honda_Civic_CXi_3-door_hatchba
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
