Hey guys.
im new to the "SAU", im just wondering if i could get a little bit of help, sorry if the thread is in the wrong spot, feel free to move it.
But, i have a r32 gtst with an rb20det.
It has a rough idle, but when you rev it and its on boost it revs cleanly.
Has anyone had this problem before?
Any ideas on what it is?
I have a feeling its an injector or something :\
https://www.sau.com.au/forums/topic/437381-rb20det-r32-gtst-rough-idle/
Mind you, this car has been sitting in a padoc for 6 months plus.
It has old dirty fuel in it.
Its not at my house though yet, i only recently just bought it. But the guy is trying to fix it for me before it comes to mine.
Would old fuel, and old fuel filter make a difference?
No an old fuel will not act like this.
I had my S13 lying for a year before the swap, I managed to start it with difficulty (very very low compression on 2 cylinders), after some minutes of warm-up it ran great. No miss or rough idle, the engine was running on all cylinders and performed "normally".
The old fuel filter if clogged or soon to be will restrain fuel flow so the engine will have difficulty to run when it weel need fuel flow. A friend of mine never changed is fuel filter, when the filter finally clogged, the engine was running like a charm at idle but couldn't move the car, as soon as it was giving some gas the engine would die.
Check for the vacuum leak (especially around the injectors), plugs and coil, rusty earth etc...
It looks like a vac leak, am I sure without having the car under my eyes ? No.
Thing is there is a lot of R&R to search, find and fix a vacuum leak, especially on a RB because the injectors seal are difficult to reach.
You can use some brake cleaner to find a leak with ease. Spray it around all the gasket/vacuum hose you can reach and listen to engine rpm change.
I don't know the RB enough to answer this question.
I didn't wired the OBD light on my S13 and I don't have a consult to check the codes when the leaks on the brake booster appears.
If the OBD light isn't ON on the dash i doubt there is a code to read but double check this with a more experienced RB owner.
No but an erratic airflow signal might throw a code, or the ECU could hit the limit when it's trying to trim the AFR with the O2 sensor. ;)
I don't know if the ECU is advanced enough to find a abnormal behavior from its sensor and throw a code.
The ecu is definitely not smart enough to spot a vac leak .
op have you paid for this car?
It amazes me how people are happy to buy cars woth problems and set a step learning curve for themselves to fix it.
Good luck with it.
Edited by superben
Hey superben, not sure if you're trying to say we are idiots or if you are actually saying its good..
But nah, i know jack shit about RB's.
I told him i dont know much about them, my mate does who is helping me and ive learnt a little bit.
But nah he's gonna fix it and then give it too me. Im just trying to help him fix it, by asking around seeing if anyone else has had many problems.
Im not saying you are an idiot, its just that buying a car with problens is a whole lot of pain, especially if you dont know about what you are buying.
Did you buy it of your mate? In that case I'm sure he will help you sort it, I thought you bought it off someone else who would just say they will sort it but not actually fix it.
Lots of small issues can cause misses.
You haven't mentioned what revs the car is idling at when missing.
I would be checking the timing and pressure testing the pipework to find any leaks, and replacing spark plugs and inspecting coils/ coil loom.
Okay, well my mate who is mechanic said...
"It sounds like a bad plug, or a weeping injector.. More so injector because if its revving clean when on boost it sounds like 1 cylinder is getting a tiny flooded from the weeping injector and is sorting itself out when high revs".
Does that sound right?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
