Hi Guys, we have fitted a Performance Metalcraft upgraded GTR sump without removing the engine.  It took a (long) day for 2 guys to do on the hoist.  It has raced on every circuit in NSW and a few in Vic since it was done.  I have not seen any oil pressure movement on the data log in over 2 years.  :)
www.performancemetalcraft.com.au
SK, what's the retail on the PMC sump kit? Also how do you reckon it compares to the trust kit (which comes with extension, baffle and new pick-up)?
Cheers,
Richard
Cheers,
Richard
You will have to ask PMC, I really have no idea what they charge.
The Trust kit is very simple, it extends the sump downwards (reduces ground clearance) and has an extended pick up and a cylindrical baffle. It increaaes oil capacity by ~1.25 litres. The PMC sump we use has wings (so it does not reduce ground clearance) out both sides with one way doors and baffles. It does not need an extended pick up. It increases oil capacity by a bit over 2 litres.
In funtion there is really no comparison, a winged and baffled sump is by far a superior solution. Hope that helps :)
just letting you know i know the boys at PMC have been making these sump kits for quite some time a couple of years and have never heard a bad thing about them. CRD highly recomends them as well, i've personally seen seem them fitted to almost stock GTR's to a 1200HP street GTR getting set to malaysia.
we too have one fitted to our GTR as well.
the kit is a work of art go and see leone at PMC down at euston st rydlemere.
same place as hi octane,different people.
great blokes!
  • 7 months later...
Hi all,
Just thought I would provide an update on the Accusump fitted to the car. Its been in for around 6 months now and have had plenty of track days since then.
In that time I have not had any problems with oil pressure on or off the track.
One of the side benefits of the system is that because the canister hold oil under constant pressure, and it releases its oil into the engine when it senses any oil pressure drop, you get oil pressure even before the engine starts.
Turn the ignition to "on", the system senses no oil pressure so it starts releasing oil providing oil pressure for start up. For this reason I leave mine on at all times.
There is a manual switch version usually used in race cars and an electric switch version (the one I am using) which can be turned on and off.
Ultimately I will move to a proper race sump such as SK has advocated, but until then this has been pretty good.
DANOOH,
Originally I looked everywhere. Was going to bring on ein from the States.
Ended up getting it from Performance Wholesale http://www.performancewholesale.com.au/
I don't know who else stocks them, but surely others must.
Cheers
  • 1 year later...
DANOOH,
Cheers
I know this is an old post but besides purchasing the 3qt. Accusump what else is needed to install this on my GTR lump in my S14 silvia? What electric valve unit to use, and mounting kit as well? I will like to order this asap for my build, I don't want anything to give problems after install and have to drop the engine and box.
Edited by TriniGT
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
