Carbon/fibreglass Parts For Nissan R & S Series, Euro Cars, Evo's - Round 3 Group Buy!
Hi there
does the r33 gtst - gtr style front grill fit an s2 gtst?
If so are there any pics of:
R33 wind deflectors
R33 front grill
R33 gtst garage defend cooling panel.
Thanks.
cool put me down for both please
Added to the list!
can i get a price for r33 gtr coilpack cover thanks
$100
Heya Elvis how much on the Evo X Varis canards? any other types u can get as well? i can modify to suit my 33 anyways
they have auto select R33 front bumper canards, $250
EVO X canards;
only have Varis $210
Hey would u b able to get the auto select canard copy for r33 gtr ?
Also do u have any pics of the
* R33 GTR OEM rear bumper exhaust shroud?
front canards? if so $250.
bumper exhaust shroud fitted to WAN94N's Wang munching beast,
Hey I'm interested in the: R33 GTS/GTST - GTR Style front grill
I will need to confirm if it fits s1 or s2 first, what model is yours?
Hi Elv,
How much is the R34 GTT cooling plate?
Do they also have the CF pillars to suit an R34 GTT, as I noticed they have them for the 33.
Any CF centre console/dash parts too?
Cheers
R34 GTT cooling panel - $95
only have CF pillars to suit 4 door only.
There is a CF stereo/shifter surround (price TBC)
Pls put me down for r33 gtr spark plug cover
Sure thing,
Hi there
R33 wind deflectors
R33 front grill
Thanks.
not sure if S1 or S2, what is the difference between the 2 grills?
i'll have to confirm with supplier.
this is the pic the supplier sent me for the cooling panel, can you tell if it is for S1 or s2?
wind deflectors will fit s1 and s2.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=384083
Happen to have a pic of R34 GTR wing blade and eye lids ?
eyelids Fitted to a SAU member's car:
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=407799
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=408597
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=408598
wing blade
trying to find a pic of it fitted to members car.
List UPDATED:
ANDREW.Y
* R34 GTR Carbon JUN High wing stands
* R34 GTR Carbon Fiber Canard (4 piece)
* R34 GTR Carbon fiber Rear Spoiler Blade
Chindo:
* R34 GTR OEM rear bumper exhaust shroud
* R34 GTR NISMO Z-Tune rear add ons
* R34 GTR JUN High wing stands
Dori:
R34 GTR Carbon NISMO Z-Tune rear add ons
evo 8 canards
damd side skirts & rear skirt add on
evo 7 hood vent
evo 8 coil over
evo 9 exhaust shield
evo 7-9 rear boot spoiler
evo 8 radiator cooling panel
LowNSlow:
S15 mirror cover
S15 radiator cooling panel
Paragon:
RB26DETT coil plug cover
The difference between s1 and s2 is the s1 has an the same headlight shape, bonnet and grille shape as the gtr where as the s2 has more squared lights and the bonnet shape is different as a result. Cooling panel is for s1 but will fit s2.
Put me down for a r33 gtst cooling panel and a front grill ( if it fits s2)
godz_85 updated! unfortunately no N1 slots.
Severe R33, so S1 cooling panel will fit S2? if i recall, it is a tiny bit shorter in length tho, if you guys are happy with this i can add you to the list.
still waiting on confirmatio of grill if it fits s1 or s2.
can anyone tell just from the pictureS?
to me, it looks like a S1 grill.
EDIT: its for S1 only guys
I will take a grill then please
OK no problem, yeah I've heard that the garage defend style ones fit but the part around the headlights doesn't sit flush, if anyone else was interested.
Put me down for
-r33 gtst cooling panel
-r33 b-pillar garnish
Also anyone know how strong the r33 carbon wing blades are? I've heard stories of some replica ones buckling at high speed. Just wanting to know before I fork out $180 haha
2 other members have purchased without any issues.
list updated:
ANDREW.Y
Chindo:
Dori:
evo 8 canards
evo 7 hood vent
evo 8 coil over
LowNSlow:
S15 mirror cover
Paragon:
L33SH;
R33 GTR style grill for GTS S1
Severe R33:
godz_85:
AS R33 GTR front canards
R33 GTR bumper exhaust shroud
FYI guys, i made mistake on the R33 garage defend cooling panel pricing on page 1 (listed as $80), it is actually $110.
Sorry about this error!
4 days left!! WE have enough people for the group buy to go ahead provided none of the above pull out.
  • Like 1
GROUP BUY HAS NOW CLOSED.
PM's have been sent to everyone requesting for deposits, except PARAGON as your INBOX is full. if i don't hear from you by Friday 21/2/14, i assume you are no longer interested and will be removed.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
