what's the goods on bulbs what are you guys using im tossing up between 3 different sets
ipf Fat Boys come in a 60w or an 80w
Philips extremes are 55w
and Osram nightbreaks are also a 55w
wattage aside im more concerned with the the throw distance does any one have experience with these?
https://www.sau.com.au/forums/topic/437685-headlight-bulbs/
If you have projector R32 light then you'll have a bad time. You'll be wasting your time as they will all look similar and the beam will be barely any better.
Wiring upgrade is recommended (run your own relays with thicker wiring for the bulbs). A must if you're going higher rated bulbs.
Or, do a HID retrofit:
(with crappy R32 glass hence the streaks)
https://www.sau.com.au/forums/topic/437685-headlight-bulbs/#findComment-7172130
If it has H1's on low beam it's a post 91, projector.
High beams will be H3.
With any of these cars the wiring must be sorted before you start playing with bulbs.
Relays need to be fitted to remove the voltage drop and to eliminate the high amperage switching loads on the dash switch, and also the high/low dipper switch switching loads.
Add a diode so that low stays on with high beam.
Then consider HID's on low beam, around 4300K is your whitest (though unfortunately still defectable) burner.
https://www.sau.com.au/forums/topic/437685-headlight-bulbs/#findComment-7173401
