I haven't had an issue with my stock VQ coils at 40psi, there is obviously something wrong with your setup if you can't run more than 21...
Are you running a wideband? Most likely the mixture is just too rich and it's flooding under boost. Otherwise, drop a set of VQ coils in there. :P
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7173016
I can't see why not, might need a little modification. I can test one out on the 34 here if you like, and see how it fits...
You may need to adjust the dwell from RB specs, not sure what mine is running though.
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7173589
That would be a great investigative pursuit haha!
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7173638
I fitted a VQ coil to the Neo 25 today, the loom plugs straight in (not sure the pins are the same yet.) and the lower section can be swapped to some extent, although the 34 lower insulator is larger where it joins to the coil. No big deal fitting them I suspect.
A bracket wouldn't be too hard by the looks of it either.
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7174195
I too noticed the loom plugs looked about right. So in theory they should work by the sounds of it, though your in the best position to find out haha.
Have been doing some searching for info on dwell time etc, with little luck. Must be hard owning one, as there is little about them.
Edited by benji-nz
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7174370
There is so much more information around on VQ25det's now, compared to when I got the Stagea 6 years ago, mainly due to my own r+d. :P
I have the workshop manual, and have translated the ecu pinout diagram, so the plug pinouts are easy to check. Other than that they should drop in using the lower insulator of the rb coil, perhaps with a cable tie or similar around the upper section.
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7174587
Maybe mate the two insulators together rb lower to fitt the head and upper vq to fit the coilpack.
Other than that, grab some toyota pencil denso coils (from a 1z-zfe?? or similar). Built-in ignitors and the supra guys swear by them.
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7174622
1ZZ-fbe is the engine you want. :P
VQ coils have built in ignitor also.
If these plug straight in, it's a no brainer. The only time I have had misfire is when the mixture was under 10:1 on ethanol and it wouldn't ignite well due to the plugs being wet.
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7174652
Hey everyone.
What is the most powerful bosch coil you can get? (Part number)
Currently running 717's and on e85 I'm losing spark over 21 psi.
Don't have the cash for big money ignition at the moment just want a cheap upgrade so I can bump the boost up a couple more psi.
What plug gap are you running? I had a miss at 0.8 so went down to 0.65 and all good.
https://www.sau.com.au/forums/topic/437741-coils/#findComment-7178567
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
