Hi Guys
So I'm planning to turn up the boost soon to about 16-18psi with a high flow and supporting mods
Getting a service done, wanted to make sure the engine is built to handle it and will pump out 250rwkw all day every day reliably.
This is what I've changed/am changing for "insurance" and my power goals so far
- full 100k service done , gates racing timing belt
- full fluid flush
- exhaust manifold studs upgraded to toyota ones
- splitfires
- metal intake to turbo
- blitz return flow intercooler
- 3inch exhaust from turbo back , gtr cat
- ebc & gauge
- new vacuum lines(old ones are cracking and brittle)
- new 52mm ASI radiator
- new breather hoses
- new radiator hoses
- new rocker cover gaskets
- walbro 255lph fuel pump
- nismo 550cc injectors
- z32 afm
- craig davies transmission cooler
- mv automatics stage 2 valve body upgrade
- still deciding on tuner/engine management
Only current issues :
- Idle hunting at any temperature, never stalls
- When starting cold , sputters and low revs , needs a push of the pedal to "catch - claned AAC , cold start valve , TB etc...
- Oil Leaking around rocker covers
What are the other weak points of the RB25DET that I should address before I put some serious power through it?
I know many have made 250rwkw easily on an upopened average RB with no issues whatsoever. Just looking for what I can do to ensure reliability without opening her up as this is my daily and I want to put my foot down at any time with full confidence.
Thanks in advance
Cheers
Edited by tripsteady
https://www.sau.com.au/forums/topic/438476-making-power-safely-rb25det/
when you say full 100k service i assume you mean waterpump, and the bearings also?
also if youve chaged the rocker cover gasket the oil leak shouldnt be there unless is coming from somewhere else
i guess the choice of ecu will be decided when you decide on tuner
looks like youve done a lot to cover yourself off
also hte half moon seals and such on the 100k service, not for any sort of safety but may be the leake, also a bitch to do on there own.
have you checked the compression or done a leak down test just to make sure there are no underlying issues with the rough idle/ start?
Yes 100km service including changing water pump , bearing etc... Ive changed the rocker cover gaskets, but the rocker cover bolt seals were all hard and out of shape.... It was also missing two bolts so Im going to by the gasket again , half moons and bolt seals + bolts. Will then be able to see what else is leaking
no i havnt actually - thats a good idea, i think i may get a compression test done.
I wouldn't worry about a comp test. It will just show up if you are on borrowed time, which technically you are until you do a full rebuild, and it's not like you will do that as a precautionary measure.
Boost it up, hope for best, but to be sure start planning an engine build in the mean time.
why do you always find a need to post the same thing on nissansilvia.com also?
RB25DETs will piss out 250kW at the rears anyday of the week without even breaking a sweat
ive already answered your question there. Ive also already said, "I know many have made 250rwkw easily on an upopened average RB with no issues whatsoever."
If you don't like my threads then stay out of them. Thanks
Nistune & Tune - That's it with the mods you have listed.
You'll be fine on stock over the 300rwkw's mark. (Turbo dependent)
Highflow OP6 will get your 250rwkws. All day every day
(mine does)
Cheers. Shouldnt break a sweat , and I have maintained it as best I could (never boosted above 12, oil change + filter every 5000km etc, always check coolant and oil level . always warm car up and check oil pressure before boosting) so hopefully it shall last me many more thousands of km's :)
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
