Yeah, I just wanted to gauge how much interest there was first as I didn't know how stagea owners used their cars. Thought it might have been more of a daily type of thing and not recreational.
If there is more interest and where everyone is located ill organise something.
Or should I just organise it and see whos free at that time?
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7187097
20-something stageas, a couple of muranos and one sedan hahahahah.
Last cruise was very well planned ans was a great day out.
Hopefully ill have the engine swap done and ready for the next one.
Plenty of notice is advised. Most weekends are good for me. Coming from Newcastle so i dont mind.
Edited by Howaitonaito
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7187443
20-something stageas, a couple of muranos and one Maxima hahahahah.
FYP. :P
Edited by M35woah
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7187734
Yeah I'm always up for a cruise!!!
Here are 2 photo's from our 15th anniversary Stagea Cruise (Oct 2011) and also last Septembers Stagea cruise.
it's a bit of a struggle to get the numbers together but with enough notice and a centralise meet up and cruise roote can get a fair few cars to come out!!!
  • Like 1
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7188154
Mentioned to Nick on Saturday at the tech arvo the need for more Stagea meet ups, even if its just a carpark meet while the weather is still good, which he agreed with. We should try & meet atleast once a month I reckon.
  • Like 1
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7188226
Guys im up for anything aslong as it involves a nice drive somewhere.
Once a month sounds good to me.
Im new to the late model import scene so im not sure how you boys roll.
Im used to cutting loose in a old school mazda, but times have changed and dont need all the bullshit that comes with that territory anymore.
Ill leave that to later on when my daughter has to put up with it in my mazda. Lol.
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7188347
any one interested in buying a new stagea nm 35 vd25det for $8800?
2003 Nissan Stagea RS Four
VQ25DET
blitz BOV
blitz FMIC
BC racing suspension (adjustable)
GCG High flow turbo
DBA Cross-Drill Slotted 4000 series brake discs all around
3inch exchaust
TV system work with built-in Monitor
Regular service every 5000kms
more than 10k receipt available for history record
please contact me on o433066925
post-64093-0-67543500-1391420327_thumb.jpgpost-64093-0-28255000-1391420348_thumb.jpgpost-64093-0-22347800-1391420363_thumb.jpgpost-64093-0-71874500-1391420378_thumb.jpgpost-64093-0-77213000-1391420390_thumb.jpgpost-64093-0-17108800-1391420402_thumb.jpgpost-64093-0-28716800-1391420416_thumb.jpgpost-64093-0-28587300-1391420429_thumb.jpgpost-64093-0-41302000-1391420440_thumb.jpgpost-64093-0-77367600-1391420455_thumb.jpg
https://www.sau.com.au/forums/topic/438553-sydney-cruise/#findComment-7188388
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
