Hey guys
my 2002 m35 is running rich
This all started when my AFM died on the m2 a few weeks ago
was replaced with a scotty AFM (thanks mate) and i knew they run a little bit more rich in the higher rpm...
At the time of replacing the AFM i stupidly loosened the BOV spring thinking it might protect the car a bit more -recircing-as the car compressor surges ALOT. Well of course this caused the car to run extremely rich due to what i assume was a massive boost leak with the spring so soft. I did like 200kms to a tank and fouled my plugs
Tightened the spring back up as much as i could and economy came back (a bit) but due to fouled plugs i knew i had to change to see if i can start getting 400km to a tank again..
Replaced my plugs a few days ago with a fresh oil change.. Feels much better - however under load , say at 3000rpm at 80kph mostly up a slight hill, I get belowing black smoke from exhaust.
Car has Impul ECU - TBE - Front mount. BOV is turbosmart plumb-back
I could go and buy a genuine AFM - but i have a feeling i may have a boost leak ? I am in talks with another user who lives nearby and our plan was as soon as i have changed the plugs to try his really good working AFM and see if the problem dissapears - failing that a smoke test machine to see if any leaks....he hasnt logged into the forum for a little while so i thought i might also ask you all - am i missing anything - all advice welcome. Just had the oil changed and the PCV valve was inspected and seemed to be ok.
Edited by Dane
https://www.sau.com.au/forums/topic/438649-m35-running-rich/
This is identical to what I had...
Scotty fixed it, after pressure testing my intake (which was fine) and changing out my discusting plugs, by getting me to put the old AFM sensor back in...
If that had not worked, next stop was O2 sensor and seeing what Consult said.
He did suggest that my inlet was good, partially because I am on stock intercooler, and nothing has been touched, so that might be a good starting point.
Good luck with testing!!
Sorry to hear Dane, Do you still have the stock ecu to test? Has the Impul been reset?
These faults can be tricky as there are so many parts that can make the car run rich. 3k is almost full torque load on the stock turbo, so it is a point where the fuel would be dumping in on the Impul map, but hopefully it is just a leak.
Do you have the stock bov to put back on, plumbed back?
Hey Scotty,
The Impul has been reset yes - cleared all codes
I BELIEVE i was given the stock ECU with all the parts...what would we be testing exactly ?
yes at 3k the boost is pretty much 15psi -the accelerator is probably about 25%? depressed when mildly accelerating up to 80kph...i thought only really high RPM would cause an excessive dumping of fuel but i often drive with the pedal depressed at 25% to get to 80kph, i think everyone does !
I might have the stock BOV - thats a good idea.
Edited by Dane
The impul map might be richer in that area, and as peak torque is around that point, it is the richest point of the map usually.
Time for an Emanage?
  • 1 month later...
UPDATE !!!! a very good one.
Turned out the BOV that i was tightening was slowly becoming loose over time and leaking boost because i didnt lock the vac nipple against it once adjusted! I was wondering why it seemed to fix the issue but then came back!
So on the drive to work this morning - the car felt way better, sounded way better, and no black shit unless I Really, really gun it. BOV is on its hardest setting. anything after a few twists and it leaks boost badly.
Edited by Dane
Is it worth abandoning the aftermarket style BOV & returning to a new OEM?
The drivability against the stock ones never seems as nice.
Great to hear you solved it though. :yes:
I found mine drove heaps better with much better high-end pull since changing to the turbosmart kompact. The stock one is too soft once your up the boost at all.
That doesn't necessarily point to the OEM BOV being no good;
Just that a 12 or 13 year old one might be no good.
For sure there a gains to be made, but I really don't like the "shunty" nature of the throttle response with aftermarket styles.
It would be interesting to see whether there is enough meat in the body of a Turbosmart to run the bleed port; or a slightly smaller version of it to allow the slight bleed off that you have with the OEM.
Not required after tuning, as the 'shunt' can be tuned out.
I have seen a 2-3 psi gain at standard boost on customer M35's, I would hate to know how much I would lose on high boost.
Yeah but broz the stockie one doesn't make it do the hectic shhhhtututuuuu
when I'm dosin' it around my streetz ain't nothin sicker.
It's worth almost head butting the steering wheel before the power kicks back in.
  • Like 1
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
